laser pointers
laser pointers
laser pointers
Eliot Feldman
I will be demonstrating hollow turning at the Montgomery County Woodturners meeting in a couple of weeks using three types of restraining rigs with laser pointers, and I have been practicing and getting ready. I don't demonstrate much. But I know enough about any type of presentation to understand that all can be lost because of a simple light bulb, a power plug, etc. And I have noticed that fooling around with my various laser pointers takes up too much time mostly because of the pressure-type on/off buttons that are located on the side of the pointers. I use them in my own shop because they are what I have and I don't mind taking the time. But I don't want to put my audience to sleep at the demo. I need three of them, each with the on/off button at the end -- ones that can be turned on and stay on by themselves until turned off. Also, because one of my rigs is the Don Derry, it takes a fairly small diameter pointer pen --3/8 inch. The other two can be larger -- 7/16 or 1/2 inch. I also would prefer something of higher quality than the ones I have, which were purchased at local office supply stores. I have looked online, but I would appreciate your input.
Re: laser pointers
Re: laser pointers
John Veerkamp
for the pressure type lasers, just get the proper sized O ring and simply roll it over the button to turn it on, roll it off to turn out.. it is now a on off switch
Re: laser pointers
Re: laser pointers
Terry Fox
LaserPointerPro.com has 3/8 dia laser pointers that turn on by screwing the end cap down onto the batteries, plus various other styles. I've bought from them twice. They ship directly from China so it takes a little while to get them.
Re: laser pointers
Lyle Jamieson
Re: laser pointers
Lyle Jamieson
Send me your address Eliot and Ill send you one of my "Castration Ring" switches. It is the laser holding devices that usually takes the time to fiddle with and get set up correctly. My system takes three or four seconds to turn on and set the laser to the wall thickness. It can be frustrating if setting the laser is not quick, accurate and easy.
