Aspen Lamp Shade Photo Essay
Brad Vietje
Got my hands on a big fat Poplar log recently (Big Tooth Aspen, small end 22", large end 25" and 14 feet long), so I brought home a 3' section to practice a few lamp shades for a project I have been thinking about for months. Yesterday I took a break from all my landscaping/gardening chores, and tried a simple "Coolie Hat" shade for practice.
BTW: a 36" long hunk of wet Aspen is pretty darned heavy! Rolled it into the truck with ramps (waaaay too short/steep) with GREAT effort. Here it is in front of my little John Deere 210 under restoration...
Cut away enough to fit it on the lathe and started roughing the outside shape, leaving things thick to start:
Found a new use for a sliding head stock when my lack of planning left the tool rest banjo stranded on one side of the 18" solid shade blank...
And the solution was to remove the tail stock, then slide the banjo and head stock down to the end so I could extract the banjo:
And then to hollowing the inside:
I decided to do this differently than Peter Bloch (the real master of all things wood shade related), by shaping the interior first, then achieving finished thickness from the outside (he turns the outside to finished dimensions first, then hollows from inside)...
Working in stages and doing my best to blend them together (not entirely successful, but off to a decent start):
Getting pretty thin -- no going back to touch up that rim now !
And the really hard part is figuring how you will get the darned thing off the lathe! My method only worked so-so, since the tree was pretty punky at the center, so I'll need to check with the master about how he does this!
And the end product -- 17" by 7.5", no finish yet, but will soak with one oil or another when it's dry:
It was pretty hard work, and I was wet and more than a little tired when finished -- a good workout ! The shape is only so-so, since there's an unintended bulge near the top, and I banged into the 1/4" x 4" GRK screws holding it on the faceplate, but a bit more advanced planning, and the next one should be better.
Safe spinning,
Brad Vietje
Newbury, VT
Might be able to pull off a curved one like this though.. Hmm..
