Portable Generator for Mini Lathe?
dick gerard
I'm thinking about next year, doing several outdoor shows, and plan on taking my delta Midi lathe with me. I would like to purchase a gasoline powered portable generator with enough output to supply the required 15 amps. So, for all electrical geniuses out there, how many watts do I need to be looking for? All the units I look at tell you watts, not amps.
Re: Portable Generator for Mini Lathe?
Variable speed lathe?
Clifton C
V x A = W
so
W / A = V
and
W / V = A
Dennis in Southern Oregon
The simple answer is 120 volts times 15 amps equals 1800 watts, which is about 2.4 horsepower. My guess is that you will never draw even half that amount of power with the mini. A 1 kW unit should be adequate. Note that this is engineering horsepower, not marketing horsepower. There seems to be a vast difference between the two with some manufacturers.
Dennis
Doc Green
First of all, I don't think a mini lathe would require anything near 15 amps to drive it. I looked up the specs for a Delta 46-460 and it has a motor rated at 1 HP max.
When plugged into a 120 volt source, a 1 HP motor that is 80% efficient will draw a current of 7.8 amps when it is delivering the full output of 1 HP. This is 932 watts.
Note that the spec said "max." Chances are that the motor on the midi lathe will never have to deliver the full 1 HP. So, we can conclude that the maximum current the motor would ever need is 8 amps. This is 960 watts.
In normal use, the motor will draw much less current than 8 amps. The current requirement varies with the load. More current is required for a heavy cut than a light cut.
My guess is that with normal turning, the current requirement would be about 4 amps or less. This corresponds to 480 watts. At this current level, the motor would be delivering about 1/2 HP, assuming the motor is 80% efficient.
So, if you purchase a 1,000 watt generator, the generator will only have to supply about one-half of its rated power output. This leaves a considerable safety margin. (1,000 watts = 8.3 amps at 120 volts)
If you purchase a 750 watt generator, you will still have a 50% safety margin. (750 watts = 6.25 amps at 120 volts)
OK? Questions? ~Doc
Hey Doc, I think we were reading each other's minds on this one.
Dennis
Doc Green
Good deal, Dennis. It's always comforting to have a backup!
Geoff Whaling
The simple power calcs are only part of the story. We have run small lathes off generators both large and small at demonstration events. I've regularly run my Nova Mercury off a 1000w Honda EU10. As a caution the VS on the Nova Mercury did die after 8 or 10 years. There did not seem to be any correlation between its demise & using a generator as died a year or so after the last generator use.
We have also run Vicmarc 100's two or three of them off 3000w generators but it pays to start and stop them seperately. btw they are 250v 1hp motors & the Mercury was 250v 1/2 hp (Australia).
I'm not an electrician or electrical engineer but I work with them. A big factor with emergency power load calculations is what they call "in-rush current" - "the instantaneous input current drawn by an electrical device when first turned on." It plays a significant factor in calculating the size of generators or the margin required above the calculated running load.
The other factor to consider is clean or pure sine wave generator technology. If your lathe has a variable speed drive it may be sensitive to how "clean" your power is from the generator.
Generators also don't like to be run continuously with light loads so plugging in something like large spot lights may help out there if the load calcs are light compared to the generator rating.
Geoff Whaling
Oh and some event promoters insist on earth leakage devices/residual current detectors and electrical safety testing before you plug in or run anything.
robo hippy
This makes me wonder about deep cycle batteries and a converter. I use one with my snoring machine, and found out when I used my guitar amp that the converter box was only grounded when it was hooked up to the battery in the car because that battery is grounded to the car. I now take a steel stake and some copper wire and run that off the ground line/green screw on the converter box. That eliminated the static non grounded hiss on my guitar amp. No idea about how long you could run a mini lathe off of one of this type of set up... No noise though.
robo hippy
don stephan
First you could rent a generator and use it to power your lathe for a day, simulating use at a show, to see if it works well. Second, some shows and especially adjoining booths might not appreciate/allow a generator running for hours. Some shows have at least a few booths with electrical supply.
Alan Zenreich
Alan Zenreich
Dick, if you can swing it, a Honda eu2000i would do the trick. Fuel efficient, lightweight, and QUIET. I have two of them and can answer questions, so give a call to discuss the options.
walta
I say spend the extra money for the Honda or buy a 300 foot 10 gage cord, because the noise will drive you crazy otherwise.
Walta
Re: Variable speed lathe?
Ivan Clark
This question needs answering.
Not all generators (or UPS's) put out a sine wave.
A VS lathe will be much more dependent on getting a good sine wave power supply.
Also, if variable speed, you probably want to get in the habit of ramping the speed down to zero before turning the lathe off. That is especially true if the lathe has a braking capability built in. The brake causes a current surge.
test
Don't do it
Dick My response will be a little different. I photographed for artists for 26 years and went to many seminars on how to improve your booth sales so I could help my clients. The general consensus was that demoing in your booth did not improve sales and often hurt. It does bring a crowd in around your booth but unless you have a helper you don't have anyone there to answer questions and close a sale. The gawkers tend to be low end buyers and fill the booth so the higher end buyers can't get in.
This was true for other artists not just turners. Blacksmiths, Fiber artists and jewelers all chimed in.
People buy the artist as much as the work and ideally you need to greet every person and be as personable as possible. Don't sit in the booth and read e-mail. My own personal experience which is very limited because I found out I don't like doing shows, was that on low end shows it didn't hurt but then I only sold low dollar merchandise at those shows. I never did demo at high end shows other than as a guest demonstrator payed by show. My experience there was it didn't help my sales at all since I had about the same totals but we did always get a few more members in the turning club from my demos.
If you do the Honda is the answer. Most artists I see that have either lights or fountains or things that run off a generator use a honda. They are quiet and don't have to be very far from the booth to not be an annoyance.
Generators...
Ralph Lindberg
OK, so I've owned multiple generators....
If you are only going to run your lathe, a 1KW Inverter-style generator will do just fine, that is a Honda EU-1000, a Yamaha , or any one of several dozen Chinese made ones.
DON'T get a cheap contractor style, don't get any kind except an Inverter-Generator.
That being said, what about other uses? Lets say you want a back-up generator for home use? Well, in that case a Honda EU2000 would be a good choice. It can start, and run, your Refer, along with a few lights.
Last winter I used my two Honda EU2000's (Honda and Yamaha's can be hooked together) to run.. Two refers, one freezer, the lights, etc. for 5 days!
Brad Vietje
Wise Man Speaks.....
Lyle Jamieson
Re: Don't do it
Lyle Jamieson
Agree 100 percent. Use the space for merchandise not a lathe.
Re: Don't do it - Useful perspecitve, thanks!
