ADVERTISE HERE - FREE TRIAL
wood storage shed
wood storage shed
wood storage shed
Currently I have my wood stash and a lot of other stuff stored in a 10x10 storage unit. I have this steel shed on my property that I plan to use for wood storage. However it was originally just a concrete pad used as part of a dog grooming service. The who bought the original small cabin expanded it into a large house that we love. He also built this storage unit on top of the slab. Here's the problem. water runs down the slab and collects against the building. You can see where someone tried to stop or slow it down by caulking. I cleaned it up and recaulked but it still runs in a little.
I plan to put a roof over the concrete area to stop most of the rain from hitting it and will use that for my blacksmith area and a covered area for working on the shaving horse. However it won't cover the gravel area to the right. All the water from in front of the garage ends up either on the concrete or in the gravel. Not sure I can drain it away. Any bright ideas. The building attached on the right is gravel bottom and has the lawn equipment.
I'm putting everything in that building up on some pressure treated spacers and can probably run a dehumidifier in there. Most wood will be stored vertical against the wall except for small stuff and bowl blanks which will go up on shelves. I found a good deal on some shelving removed from an electrical service truck so I put that together yesterday. The rolling cart will store plywood and other lumber vertically and will more or less be in the middle of the room but obviously it will roll to give me easier access and more room to other shelves.
I have a contractor to build the garage and do a couple of things on the new shop. I will do all the rest once I have a place to unload the shop equipment so I can get to my tools to do the work. It's been a pain finding someone. I thought I would have a new shop within 3 months. It's been 2 and so far I still don't even have the garage.
Re: wood storage shed
robo hippy
Well, water does flow down hill. I am guessing you are talking about the slab next to the basketball hoop. One solution could be to have a concrete cutting company cut a groove that tapers from almost nothing down to the gravel. Probably expensive. It would help if there is some sideways slope to the slab. I have done houses where we would put in a strip drain that would do the same thing. A bit late for that. You could also cut out a small strip and fill it with gravel so the water could soak down through it. You don't want standing water on metal as it will rot. I did a driveway for a machinist who set it up himself. He was really proud because it was 'dead level'. Where's the rain water going to go???? We fixed it...
robo hippy
Steve Criscenzo
Gravity is your friend. You just need to figure how to use it. Is this area in a low spot so you can't get drainage away from it? I would start by adding gutters and then extending downspouts as far as you need to get the water to flow away. Strip drains in front of the buildings will help if you can get fall. I sure would not want to depend on caulk.
Gravity may be your friend, but water is your enemy. Caulk is Make-up. (Ask your bride what make up is if you don't know.) Its not a fundamental solution. You have a fundamental problem.
Be very careful. Think this through and think LONG TERM. You want to make gravity work for you. You must. Or it will sneak up on you and you will start to find terrible problems. As a Home Inspector I see it almost every day. Its worth spending the time and money to get right and make the water flow away from the building. Better to rely on surface drainage if possible.
I would consider cutting the storage building loose from the slab and jacking it up and pouring a new slab on top of the existing slab to elevate it to the point the water would not come in. OR, lower the surrounding grade.
Water runs down hill. Figure out where you want it to go and make it happen. Give it somewhere it woudl rather go.
Look at your picture of the inside (Door?). Note the stains from water soaking up from the bottom. That's bad news.
adding a gutter
forgot to say that the roof I put over the slab will slant down toward the shed and over hang it. This will make the water run onto the shed. Then I will put a gutter on the bottom of the shed roof and run it down the back side. That should take care of most of the water on the slab. The water hitting the gravel is going to be a problem because the lowest point is right in front of the left door.
Glen Key
French drains, others have already said it, make gravity work for you.
robo hippy
To put in a strip drain, you have to cut out some of the slab, then repour the part around the drain, and of course, the low end of the drain has to be able to move water away to some place lower. Drainage can be a real puzzle. Loved doing houses in the hill where one side of the drive way was 2 feet below the street, and the other side 2 feet above, and the house was down hill from there..... We do get some rain here... Well, days in a row of drizzle...
robo hippy
Walta
Does this same slab extend under the house?
Is this shed framed 24 inch on center?
Is it legal to have a shed that close to the house where you live? Most require 10 feet of separation.
Often electricity is not allowed in sheds.
If you can get permits the smart move is to move the shed to a new higher slab 10 or more feet from the house. So a shed fire is unlikely to become a house fire.
Walta
thanks for the input
It's going to be interesting solving the problem because the low point up to the building is in front of the left door on the building on the left. The slab itself under the building does flow down hill but would be a pretty big hassle to trench through the concrete. The money isn't there to do anything major which is why I may simply have to make a way to control how the water flows through the building and then deal with the humidity.
The building on the left is the shop/garage and it's about 30 feet or more from the house.
Mike Jones
How about building a planter box in front of the building that stops the water from coming off the slab into the building?
Interesting thought Mike. What I'm going to do is put a roof over the slab that runs down onto the shed roof, then put a gutter on that to run the water off to the left and downhill away from the shed. That won't stop the water from flowing onto the gravel area which unfortunately is the lowest point. I'm thinking about digging a 3 foot deep hole in front of the doors and filling that with gravel. Maybe with luck the water would drain down into that and into the soil and not the shed. At least for small rains anyway.
