AS most of you know I'm getting married saturday. Part of this moving in with each other is we have a lot of different garden machines including my chainsaws. I have fuel mixes of 50:1, 40:1, 32:1 and 33:1. Other than the chainsaw and weed eaters most aren't used that frequently but it's going to be a pain to have a 4 different gas cans. Well count 5 since the lawn mowers only use plain gas. What is the easiest way to have all those mixes. You guys have any secrets.
John - it's easy. Just buy all Stihl. Chainsaw, weed whacker, edger, blowers, etc all use the same mixture. So for me it's 2 gas cans - one plain gas and one mixture. Just tell her you're buying yourself a wedding gift and head to the Stihl dealer:-) Congrats again on the upcoming nuptials. See you in September in Dalton.
If it was me, I'd run them all at 40:1, or so. You'll get some purists that will find this to be heresy, but that's what I've been doing for 40 years and never a problem. Besides - if you look at that 50:1 ratio, the fine print probably says with oil purchased from the maker of the saw, or whatever it is, all other oils run 32:1.
John, it is better to err to the lower ratios than higher, the worst that can happen is sooting up the engine or at least the spark plug.
On the other hand, mix oils have improved so much since the days of 32:1 (pre-2000 if I remember correctly) that it's less risky to use a higher ratio than recommended especially if you use a synthetic oil such as Amsoil.
I would use two mixes: 50:1 and probably 36:1. Use 1 gal. jugs, labeled clearly and put your straight gas in a 2 gal. or larger can to avoid confusion.
Congratulations on the hitch-up! I have been out of the loop too long, so was one of the few who didn't know.
I only have 1 mix of 2-cycle until I find my old McCulloch which wants 32:1.
I did learn something interesting from a Husqvarna dealer recently, however. They said that 50:1 is to pass EPA tests and reduce blue smoke at start-up, but that they recommend using 40:1 for extended saw life. So, the manuals all tell us 50:1, but they say the saw will last longer and have fewer wear related failures at 40:1.
40-1 here also. 1 pint in a 5 gallon jug. 021 Stihl 25 yr old and still strong. 262 Husky 20 yr old and still strong. Also back pack Stihl Leaf Blower, 2- Ice Augers, Snowblower, Stihl Brush Saw, Stihl Concrete saw, and more. I would not change. I do buy good branded oil and plan to change to full synthetic shortly.
A warning to all, times have changed! A little extra oil never hurt was my thought for many years. It is a wrong thought particularly for the synthetic oils but I guess for any of them since engines are tuned lean to near death from the factory now to suit EPA standards.
Synthetic oil doesn't burn in a combustion chamber. When you add extra synthetic oil instead of richening the mixture as you would intuitively think, you are leaning it out! Less burnable fuel for the same timing advance. You can and many people do burn up two cycle equipment running it too lean by adding extra oil on the old "if a little is good . . ." theory.
I read that even with standard two cycle oils the engines are leaned out the same way. I would think at least a little of the standard oils would have to burn but apparently not nearly as much as gasoline.
I do mix everything 40:1 with the best synthetic I can find. However, I also tune all of my engines to that mixture. Now that I understand that both more and less two-cycle oil than needed is bad I very precisely measure my 40:1 mix and resist the temptation to just dump in the bottom of a bottle of oil. When I did the math to see how much the difference is between 50:1, 40:1, and 32:1, I found that I have often been guilty of running a far different mix than I thought I was running in the past.
So far I haven't found anything that didn't run well at 40:1. That goes in my chainsaw, weedeaters, outboard, anything that wants premix.
We have a local husky dealer that sells Arnold Universal Oil mix. One tube per gallon for all ratios. I'm a light user of my saws and equipment these days so I can't vouch for the engine longevity using this mix however.
I mix small batches of fuel because I have the same problem. I have mixed as little as 4oz of fuel (to finish up a job) using this method. Get a 2-4 cup pyrex or poly measuring cup and some 10ml syringes (no needles) and only mix what you need. The 10ml syringes and measuring cups allow to to make exactly what you need in pretty exactling proportions (it is very easy to measure fractions of an ml with a syringe). So lets say you need to make about 16 oz of 40:1 fuel. You add 2 cups (480ml) of fuel and 12ml of oil, etc
