"Gold" veins??
Peter Rand
How can I fill cracks in wood, hairline and wide, with “gold”, so they appear as ‘gold’ veins in the otherwise natural wood?
"Gold" veins??
Peter Rand
Rub-n-Buff is an ideal material......
JamieDonaldson
..... for such applications, apply after sanding sealer and before final sanding. Its available in a great variety of colors, and I have used it in antique restorations for many years.
ditto what jamie said
Re: "Gold" veins??
Brian Roberts
I would use brass powder and CA....works well for cracks of all sizes.
I really can't imagine filling cracks with Rub 'n Buff.....
Is it not a colored wax designed to be rubbed on the surface of......stuff?
Re: "Gold" veins??
Peter Rand
Thanks Jamie, John, Brian - The problem I've had is the 'carrier' (wax or solvent of some kind or CA) of the "fill" and its spillover from the crack interferes with the final finish. What is the best 'sealer' to prevent this? Should the fill be done AFTER final finishing?
What's your idea of a wide crack?
Dick Coers
I wouldn't use CA on anything over 1/16". Over that I would use epoxy. Personally, anything over a tiny crack in a knot, and it's to the burn barrel in my shop. I don't care for cracked work, and I have no shortage of wood.
Re: What's your idea of a wide crack?
Peter Rand
size? - tiny to a couple of millimeters wide - I just like the natural crackle character of many beautiful woods - like many nice people!! :-) and would like to highlight them.
Dick Hines
Go to your big box store and ask for some of their key dust from their key cutting .
I put them into an "OLD" coffee grinder ans make a dust. Fill the cracks and flood the dust with thin CA. Make sure there is a lot of air flow around your working area. The CA will put off a lot of smoke and fumes.
After the CA dries sand. and put your finish on the piece.
Remember "LOTS OF AIR FLOW!"
Re: "Gold" veins??
Brian Roberts
Do a pre-seal with sanding sealer...whatever is compatible with your final finish.
The goal is to prevent the CA from soaking in to the surrounding wood.
After filling cracks with brass powder and CA you can do a final cleanup pass with a sharp gouge to remove excess fill and the sanding sealer....or most of it.
Any process that is new to you should be done on some less valuable wood to learn first....just jump in and try it.....it works pretty well.
Re: "Gold" veins??
don stephan
My personal preference is to use CA and sawdust for fine cracks, or epoxy tinted with dark brown or black fresco powders. Looks much more natural to my eye than gold, turquoise, brass . . . - never have seen any of them in raw wood.
Not that many keys are solid brass anymore
Dick Coers
So the old source for brass shavings is going to be gone in the not too distant future.
