Dust Collection Ideas needed
Dale Bonertz
In a few months I am going to move my lathe for better access front and back. I plan on centering it in my 10' wide shop so I can turn inboard and outboard. By doing this it will put the lathe about 5' off each side wall making if difficult to have the dust collection hose on the floor (I don't want the hazards this presents either). My dust collector has its own room outside in a tool shed I built for it. It is a two bag 3hp 1900cfm collector with a six inch main line (metal) and 6" flex hoses to machines. The dust intake comes through the wall at roughly two feet off the floor. I have it elbowed up to the 9' high ceiling then it runs to the band saw. Currently for the lathe line has a "T" where it comes out of the wall and I have a metal line about five feet over to the lathe with a short 6" flex line to the dust hood. I will abandon this line and cap the "T'. I envision using a "Y" at the ceiling where currently there is an elbow. I then will run a line along the ceiling over top of the lathe with an elbow going down to the lathe. This is where I am having a tough time envisioning the drop. I am thinking about putting a "Y" at the end of the drop so I can have a line on the front side and back side of the lathe. I want to be able to lift and hold the flex line up and out of the way when not needed on both sides. My current thinking is attach a sona tube off the "Y' for the flex line to accordion into and then have either a pin or door to hold it up.
Questions:
1) The elbow from the ceiling down to the lathe. Should this be directly over the head stock? I think this would help with access for inboard and outboard turning. You comments or experience please.
2) Anyone have any other experience or creative ways to get the line up and out of the way? I would rather not use quick disconnect since I would then need to store the lines somewhere (shop space is a premium for me 10' x 29'). Also I am not real tall (5' 9") but I would like the bottom of the the line once stored at least 6' 5" off the floor so visitors don't smack their head.
3) I am thinking I would like the blast gates off of the "Y' before the flex hose but I am not apposed to putting them on the end of the flex hose. I just thought it might be easier to store without the blast gate being in the way. Your views of pros and cons?
4) Last question. What is the best/easiest way to attach the 6" flex line to the lathe once dropped and wanting to use for collection? I would want something simple, quick and effective. I am thinking I won't be able to use the dust hood (home made big mouth) due to the storage issue.
Sorry for the long post. Anyone have this type of setup and how have you resolved these issues? Even if you don't have this setup what creative ideas do you have to make this effective for me.
Thanks in advance for your thoughts.
Re: Dust Collection Ideas needed
Don Evans
Dale:
Couple of comments:
First understand, and I think you do, dust collection is about moving as much air as you can. It works differently than a vacuum system.
It's job is to move the light DUST away from you so you don't breath it, is is NOT a chip collector.
With that said, I think it is a bad idea to have 2 inlets at the lathe with one on the front side! You need it on the back side only so that air is moving from in back of you then across the wood cutting area and then on into the inlet of the collector.
With tool control and being aware of how you sand things you can greatly help it do a better job also. For example when sanding with the lathe turning same direction as you cut holding the sand paper on the bottom of the object will direct the dust towards the inlet.
For the piping questions, every 90 or elbow you add is the same as adding 15 feet of pipe, this of course varies based on size of pipe at the point.
Never use a "T" in the line it cuts the job the collector can do greatly downward.
A big gulp is a good inlet behind the lathe, my only complaint with them is the 4" inlet. I wish they made one with 6".
I could tell you lot more and could probably write a book on this but I don't have the time to do that.
Let us know what you come up with and keep asking questions it's cheaper than making mistakes that have to be corrected later.
You have the biggest thing out of the way and that is moving the collect out of the shop but for efficientcy you need a way for air to get from that area back to the shop. Because you have a bag system not a cyclone I would suggest a grill with a good heap filter in it. One just like the one in you house for heating system works great.
good luck
Don
robo hippy
I have seen quick connect/disconnect hook ups for hoses, maybe having that on a metal drop down would do the trick. Of course, most of those fittings are for 4 inch. You could use one of those lever type cinch type clips too, or even a bungee cord. Another option might be to move the lathe just a bit out from the wall to allow room to turn outboard, but not enough to really have access to the back side of the lathe, which you don't really seem to need.
robo hippy
John Spitters
First off you want to eliminate as many elbows as is possible in your system, Replacing the elbow at the ceiling with a "y" connection is a good start, from this point I would run a straight line along the ceiling to directly above your lathe headstock, then use an elbow to direct the line downward, attach the elbow in such a way that it is able to pivot off of the straight line along the ceiling, the line that drops down should be of smooth wall pipe with as little flex hose as possible to get you to where you need to be at the headstock. With the elbow joint at the ceiling able to pivot it will allow you to be able to swing the downward portion up towards the ceiling to get it out of the way.
I did something similar using 6" PVC however my pivot point comes off of the wall behind my lathe.
I've tried to attach a picture however the file size limit is so small on this site that I can't get the file down small enough and still have a picture that is worth looking at when I reduce it to such a size. So you'll just have to use your internal visual imaging sensor.
Dale Bonertz
Thanks for the replies guys. All good thoughts . I am trying to create two lathes in one by using the inboard and outboard side of the lathe. This is why I want to center the lathe in the middle of the ten foot wide area. It will give me room to throw chips and still work when rough turning. It will also make cleaning around the lathe easier. This is why I want to have a dust collecting drop on the drivers side of the lathe and passenger side of the lathe. Depending on what I am turning I can have the dust collector working in the correct position when sanding.
I am really interested in how to get the flex hose out of the way so I won't hit my head on them when not in use. The quick disconnect as Robo mentioned are generally 4" and as John and Don have correctly said is that having the larger pipe as close to the machine as possible works best. I also don't really want to find storage for the pipes once disconnected. I could swing the joint as John suggested but what to do with the flex pipe that would be dangling if I don't come up with a way to secure them prior to swinging the elbow (again I would rather not remove them). Any creative ideas for doing this?
Your responses are getting my wheels rolling which is why I posted this in the first place. Bits of info here and there and pretty quick ideas come forth.
Thanks
Re: Dust Collection Ideas needed *LINK*
david delo
Dale,
These are used for welding applications but you might get a few ideas from this site.
Extractor
Rick Haverstock
Hi Dale,
When I was putting together the dust collection system for my shop I needed some sort of 6" quick disconnect for the jointer and planer to share one blast gate. Look at the link for McMaster-Carr and you'll what I ended up using. After 6 years of non-pro usage, it still works well for me. I suspended the flex pipe off the ceiling joists with some ugly home made hooks so I don't bang my head on them. It would be great if one vendor sold all that we needed to put one of these systems together, but alas I've never been able to find them. Good luck!
Rick
Quick Disconnect Clamps
Dale Bonertz
Thanks guys,
I have some ideas flowing now. I am with you Rick, it would be nice if one company sold everything but alas that is not to be.
If you route around in Bill Pentz's site, I think there are articles on how to make your own PVC fittings, Including Wye's. Used a home made sanding drum on the lathe. Just interesting enough to make me wonder if I should try it.
Dale Bonertz
It has been several years since I was at his site. I may need to revisit it. I learned a lot by his site about dust collecting in general. One reason I want to stay with six inch line all the way to the lathe and while dust collecting. I had to reduce to 4" for the band saw because of the port. I still only have about three foot of 4" flex pipe though.
With all the advice I think I am getting close to having this figured out in my mind. I am not doing this until September so I have time to finish the planning but now I have ideas to work on.
Thanks all
John Spitters
I managed to upload a picture that shows the pivot point on the 6" PVC arm that swings out to the lathe, if you look closely you can see that I cut a slot into the elbow and that the elbow is now secured in place with a single screw turned into the downward section of the 6" PVC pipe. I've had this setup in place now for apx. 4 yrs and it still functions very well.
This pivot point has allowed me to swing the DC pickup in place whenever I do any sanding at the lathe but also will quickly swing out of the way and up against the wall when not needed.
