Thank you John Lucas!!
Ron Bauer
After looking at the recent video posting from John L. about using a router on the lathe I decided to give it a go. The body is maple with walnut and maple darts. The finish is mineral oil/beeswax/carnauba wax. The rim had to be fairly wide to accommodate the darts but I didn't want the entire piece to be that heavy. The solution was to undercut the rim which was done turning on the back side with the lathe in reverse. I found this to be much easier than trying to turn conventional and reach wayyyy out across the ways or set up a hollowing rig. Any way, thanks for the inspiration John.
Re: Thank you John Lucas!!
Beautiful Ron
Re: Beautiful Ron
Jimmy Edwards
John would you post a pic of your jig for your router you use and the router. My social security check comes in the 1st and may just have to buy one.
Re: Beautiful Ron
I have several. first what you need to do is build a table for your lathe. It can either fit in the banjo or fit on the lathe bed. For mini lathes it's easier to do on the bed but I've made a table that fits in the banjo by countersinking the metal adapter into the wood.
Making the table takes a little imagination on your part. You need a metal or wooden tool post and then some what to attach this post to a plywood table. My early ones had a metal post (1" for my banjo) and I welded them to a large washer. Drilled holes in the washer and mounted this to the plywood. My later one has a piece of all-thread rod and I screwed it onto a metal floor flange that I re threaded to fit the 1" x 8" tpi rod. I like this one because I can install a nut on the all thread to set the height of the table. Most of the time the table is set so the cutter is on dead center of the work piece but there are some advantages to having the cutter lower or higher than center.
I have made the tool post out of wood but they wear out quickly from the banjo locking mechanism. However in a pinch it's quick and easy to make a platform totally out of wood.
Here are some photos.
The router holder
Then you have to build a fixture to hold the router, Dremel, Die Grinder or Fordom hand piece. Depends on what you have available. I use a Trim router mostly and prefer to mount it at a 45 degree angle. The reason I do this is you can use the outer edge of router bits to do the cutting to get cleaner cuts.
What I found was that a ball cutting bit would leave a fuzzy bottom on the cut because the center of the bit doesn't have as much surface speed as the outer edges. By tilting the router at 45 degrees you are using the outer edge of the bit for the cut and get a cleaner cut. I also found that 90 degree bits don't cut a 90 degree slot. They cut something like 87 degrees. Freud does make one that cuts 90 degrees. I found that by using the outer edge of a straight bit tilted at 45 degrees I get a perfect 90 degree V cut that is cleaner on the bottom so it doesn't require sanding.
Here are a few fixtures I made to hold the routers.
INdexing *LINK*
Most of the time I use some sort of indexing jig to hold the workpiece steady while routing. If you lathe has indexing use that but I've found that it often doesn't have the right number of holes. My early jig for fluting spindles was simply a round disc attached to the handwheel. I would draw or mark off the number of spaces I wanted and then simply align these with a wooden strip attached to the headstock and clamp it with a squeeze clamp. Later I got fancier and made one out of plastic with pre drilled holes but then I was limited to some division of 24 since that's the number I drilled in the plate.
Finally I found the ironfireLLC plastic index wheel. It is fantastic, inexpensive and indistructable. It fits between your chuck and headstock. YOu do have to jury rig some sort of holding device. A simple L bracket locked to the bed of the lathe works well. On my powermatic I screwed a permanent one to the headstock.
You can buy more expensive metal ones. I haven't looked for a while to see whats available but Alisam used to sell an aluminum one. The Blue one below is theirs. The Ironfire one is yellow. I'll post a link to it.
The advantage of the Ironfire jig is you have a huge number of divisions available. The downside is they give you a very small odd diameter pin to lock the jig into your homemade locking device. I made a wooden handle to make it larger and eaiser to find when you drop it on the floor. It matches an odd size number drill if you want to make your own and since you have to drill a hole in index locking block it's nice to know this. All my tools are currently locked into a storage unit so I can't measure it and tell you. Perhaps someone else will be able to. I do have the index pin because I just did a demo and perhaps I can remember to take it to the club meeting tonight and measure it to tell you what size.
http://www.ironfirellc.com/
mirror
Here are some examples of the set up. You do need a fence or guide for the router to run against. This could be straight or curved depending on the groove you want to route into the wood. In this case I used a straight cutter mounted at 45 in my sled. The fence was adjusted so the router started the cut fairly deep and then faded out. This will give me a pointed detail in the final turning. I routed one set and then readjusted the depth of the router and routed another set. then glued square dowels into the grooves. I had to glue them in a few at a time because the squares would bump against each other. I would glue in a set, turn them flush with the wood and then glue in another set. After they were all done I turned the final shape.
ornament
Here is an ornament using roughly the same technique but the grooves were routed on the router table. Something like this is what started it all. Route the rabbits. Glue in a wood. Route again less deep and then glue in a contrasting wood. Now cut off sections to ornament length and turn.
Re: Beautiful Ron
Ron Bauer
Jimmy, I recommend you view John's video. It is full of good stuff!. Ron.
Re: Beautiful Ron
Sergio
Hello John, I do not undestant how can none put a register and a chuck on a lathe. It seems to me that there is not enough space for both on the spindle thread. How you did it? Furthermore is the pin jig bolted to the ways that goes in the wheel part of the jig? Did not se it on the internet site you postEd.
Thanks.
Re: Beautiful Ron
The ironfire index wheel is only 1/8" or less thick. There is plenty of room of every spindle to put it on and then a chuck or faceplate. They do supply the pin and give you instructions on making something to use as an index block. I glued the block on my lathe because I knew I would be using it a lot. If you look at the photo of the blue Alisam index wheel you can see an L shaped device they use that sits on the bed. You can build something like that too fit on the lathe bed.
