Fuzzy detail gouge
Fuzzy detail gouge
Fuzzy detail gouge
bill tucker
The chalice is almost finished and it's looking pretty good. It just needs a couple of beads and coves to separate the base and stem. My new itty bitty Thompson detail gouge should do the trick - fresh edge - easy now - gentle touch. Eyes won't focus and the gouge looks fuzzy - Crap! No amount of "design challenge" thinking can fix that! This brings me to my question and appeal for this group's knowledge. Having done the obligatory cataract surgery, my eyes seem to be changing. Distance has improved, but close-up stuff will fade to fuzzy, even with 2.0 readers. To finish the project, I stacked 2 readers front to back on my big nose and soldiered on. The better solution would seem to be one of those headband magnifiers for close-up work. But then you get into a dizzying array of styles, powers, and focal lengths. Judging from past posts, there are many other sets of "old eyes" in this group and your suggestions and solutions would be most welcome.
Thanks,
bill
Re: Fuzzy detail gouge
Chuck Engstrom
Hi Bill -- I have a Donegal Optivisor with #2 lens set and find it very helpful, comfortable, well-made. I'm not sure if #2 is the standard strength, but it' seems just about right for me. This brand is available from many sources with widely varying prices, so look around.
Best-- Chuck
http://www.doneganoptical.com/products/optivisor
Dennis in Southern Oregon
See your eye doctor. There are several possible causes for the effects you describe and some are treatable. My wife went through a similar post-cataract situation a few years ago.
Clifton C
Bill, I know there are a lot of models out there with a lot of features,
but I like the weight (very light) and the simplicity of the MagEyes Magnifier.
The other things I use are the stick on diopters for my safety glasses,
I use the ones from Graingers OPTX2020, but there are others out there.
cc
Maybe raise your lathe
Dick Coers
Getting the work closer to your eyes may also help. Better on the back too!
robo hippy
If you are buying the cheap reader glasses at the store, they can actually damage your eyes. I used them for a bit, but broke down and got a prescription. Amazing what I could see....
robo hippy
Harry Robinette
Harry Robinette
Call your Doc before you use cheap magnifiers,you can do really bad damage to your eyes if there not healed completely.
Sister almost lost site in one of her eye's.
Don Evans
U should absolutely see your doctor about this but something that no one has mentioned to you is the focal distance these magnifiers have.
The stronger the len you put in them the shorter the focal length.
With the least powered lens with them is usually 1.75 and that strength will give you just 14.5 distance to the object, that's too close for turning work and safety in my opinion.
The ones I like are the one's that do not have the shade built into them but is really just a band with the lens in them. They are made by the company that Chuck mentioned. I have 3 or four of these mags from different makers but I only use them for work at the bench, not turning.
Remember things appear further than they are so it's would be easy to hit spinning wood with the tool tip before you are ready.
Don
Try progressives
When I had my cataract surgeries a year and a half ago, I opted to have both eyes corrected for distance vision, instead of optimizing one eye for distance and the other for reading. Since the intraocular lenses can't change shape, things start getting fuzzy at about three feet away and get fuzzier as I get closer to them. But, it isn't uniform.
As a solution, I had my optician make me a pair of progressive lenses that vary in strength from about 2.25 to zero over their full height. I can now read a book or view my computer or turn a bowl with clear focus at all distances. For driving or hiking, where I don't need close vision, I take off the glasses. If I need both near and close vision, I wear a regular pair of progressives, where the top half of the lens is essentially uncorrected, and the progressive magnification is in the bottom half of the lenses.
Anyhow, this is the solution that worked out best for me. Depending on what kind of lenses you had implanted, it might be different for you, but I would definitely suggest seeing your opthalmologist soon.
Ellis Walentine, Host
Re: Try progressives
bill tucker
Thanks everyone for the info and good suggestions. Made the appointment with the eye doc this afternoon and will probably get progressive safety glasses afterwards.
bill
