Re: why take the insert out *LINK*
walta
What you need to remove the insert is an impact.
The way I do it is clamp a piece of plywood on the jaws of the chuck and put the ply wood in a vise with the insert facing up put a 24 inch Crescent wrench on the insert and tap the wrench with a hammer.
I do own the nova wrench It is handy is it will fit between the chuck and head stock.
http://www.teknatool.com/products/chuck_accessories/spanner.htm
Most any service station should have an impact wrench and socket that would free the insert in seconds.
I think a pile wrench is a poor tool for this job as it will tend to crush the thin aluminum insert. Even if the insert survives the hardened steel jaws will damage the soft aluminum.
I hope you are lucky and have a genuine Tekatool insert and not the cheap knock off sold by Woodcraft as it features rounded corners. The insert is a nut and I call a nut with round corners stripped!
Walta
horrible freight
