PM45 tailstock riser.....
Brian Roberts
Of course the tailstock needs to raise along with the headstock.
The 2 inch plate I have been using (MIC6® Aluminum Cast Plate) for the projects posted here is not thick enough to get a riser and a key to slide between the rails on the lathe......hmmmmm.
Just adding a plate to the bottom of the aluminum? Aluminum does not slide well on steel....long term....it will gall or scratch.
So...added a steel plate to the bottom to take care of riding the top and insides of the rails....(this too was scrap...which explains the "extra" holes)...and, of course, the center two screws will come out when I make room for the bolt that will tighten it to the rails when in use.
As was the case with the headstock, no time spent at the factory to make things square...or pretty!
So machined the top of the riser to fit the tailstock snugly and the bottom to fit between the rails for a snug, sliding fit.
Like the headstock...I will scratch around the riser, manually machine as close as possible, pin and bolt to the tailstock, and back to the belt/disc to finish to the tailstock. It really goes quite quickly with a 60 grit belt on the PM31 sander.
Updates later....
Same disclaimer.....to all the naysayers....I don't do it to make money....or to make "new" out of old...I do it to keep the brain working and because IT"S FUN!!!!
Thanks for looking!
Brian
Re: PM45 tailstock riser.....
Lyle Jamieson
Lyle Jamieson
Agree, there is tremendous satisfaction from the ingenuity needed to succeed in a project like this. Enjoy the ride.
barry rockwell
Barry Rockwell
What a great project Brian. You gotta go with whatever keeps the wind in the sails!
