PM45 headstock riser ......
Brian Roberts
The project is going well!
Headstock riser made from some more 2" scrap aluminum (MIC6® Aluminum Cast Plate).
Programmed to drill the holes for SHCS's and locating pins and machine out the the inside areas. The outside was not so easy! Powermatic didn't waste any time on making things square....or pretty. so...pinned and screwed the riser to the headstock....
....scratched a line around it and took it apart and bandsawed to the line. Then screwed it back together and took it to the Powermatic belt/disc sander to finish it to the headstock.
I may fill the gaps between the two after it's bolted to the lathe...and prior to final paint.
All in all...moving along quite nicely...
To all the naysayers....I don't do it to make money....or to make "new" out of old...I do it to keep the brain working and because IT"S FUN!!!!
Thanks for looking!
Brian
