Lathe making rumbling Sounds
dick gerard
I have an old general 260 with the riser blocks. Purchased it through Rude Osolnik back in 1986 (?). lately, whenever I turn small diameter objects like handles for pizza cutters and ice cream scoops, I get a deep rumbling sound, especially when I switch the lathe off and it winds down.
I have faithfully kept the zerk fitting full of grease so I am unsure what is going on. Any ideas?
Re: Lathe making rumbling Sounds
robo hippy
First guess: bearings. They do go after a time. There will probably be a little extra run out as well.
robo hippy
Dave Paine
Bearings would also be my first guess. The sound and age of the machine.
Bearings wear even when properly lubricated. They just last a lot longer with correct lubrication.
Try and mount a long bar in a chuck then see how much vertical movement you get by applying pressure at the end of the bar. You may be able to feel the movement.
I am not familiar with the lathe, so no idea how much effort to remove the bearings. Likely you need to remove the spindle first.
The bearings should have a code stamped into the shield/seal. This is how you find the correct replacements. A decent bearing speciality store will be able to look up the code and find an equivalent bearing. If you are replacing one end, best to replace the other end as well.
Likely the rumble is the headstock end bearing.
Process of elimination first
Dick Coers
Take off the belt and just run the motor first. The tension on the belt can also preload the bearings a little, and change sounds. Now inspect the belts, looking for cracks and missing peices. If motor runs smooth and no noise, and the belt is good, it's the head bearings. Might run a year if there is no runout.
clay foster
First, make sure it's the lathe, not you, that is rumbling when you turn ice cream scoop and pizza cutter handles.
Brian Roberts
When checking for any abnormal movement check the bores for any wallowing in addition to checking the bearings themselves.
If you continue to run with bad bearings it is quite possible to damage the bores.....which can be expensive to repair.
Harry Robinette
Harry Robinette
I have a 160 and it did the same thing,I took the Reeves drive completely out cleaned reinstalled and regressed the unit. It worked good for a couple days then I was told to adjust the belts tightness that did the trick been good for 5 years or so now.
