Veritas - Innovation in Tools
American Holly
American Holly
American Holly
don stephan
Good friends are very upset that they had to remove an old holly tree, and have asked me to try to make some keepsakes. The tree service left the lowest 4' of the trunk, about 12" diameter at the ground and perhaps 8" at top, not perfectly round.
Some items they said would be great are of course small bowls, candlestands, some tops for their daughter, . . . The bowls would be once turned green, the other items would require trying to dry the holly without extensive cracking/checking.
Anyone have any experience with once turned holly bowls? Anyone have success drying pieces of holly for spindle turning?
Thanks in advance.
Re: American Holly
Re: American Holly
I've never been able to dry it without getting a blue stain. Haven't had cracking problems but it warps pretty badly. Haven't turned green bowls from it so can't answer you on that one.
Re: American Holly
Holly can be problematic to dry,.....
JamieDonaldson
...and the sooner turned the better chance of avoiding the spalting/staining. I cut holly spindle blanks to size and air dry as soon as possible, microwave without excessive heating also helps, and make sure you eliminate the pith. I've also had some luck misting freshly cut blanks with a 10% Clorox/water solution to retard staining.
Re: American Holly
Re: Holly can be problematic to dry,.....
Ralph Lindberg
Dave Schweitzer (D-way tools) passed along a tip for drying Holly and keeping it white (vrs the ugly grey/blue staining/spalting it gets)
Wrap the wood in plastic wrap and put it in your deep freeze and forget about it for a long (years) time.
The wood freeze draws, and since it's frozen the fungus isn't active and the wood stays white.
I know that Cook Woods likes to get Holly into the kiln within a day of cutting it down.
Re: American Holly
Re: American Holly
Mac Ray
I have found that spraying both maple and holly with concentrated lemon juice helps retard blue staining....seems to work for me.....both need to be roughed out as soon as possible after harvest,sprayed with lemon juice and put in brown paper bags to dry....this usually works for me....give it a try.....
Re: American Holly
Re: American Holly
Bill McWhirter
I have had some success preventing the bluish staining by getting the bark off as soon as possible. I would also seal the ends and split it down the center to minimize cracking.
Re: American Holly
Re: American Holly
Jim K from Trappe, PA
I've used Kleen Strip two part wood bleach to make holly whiter after it has been stained. You can see the stain, but it's not bad. I know it made the holly whiter, but don't remember if it reduced the stain. I guess it depends on what you are trying for. Since there is some stain, you can quickly tell it's wood, but that may not be your goal. You also need to make sure you are not using a yellowing finish on top. I used water based poly on this piece.
Jim
Re: American Holly
Re: American Holly
George
Bill,
That is an interesting idea. I would imagine the acid in the lemon juice retards the fungal growth. I wonder if something cheaper like white vinegar would work? Although, the acetic acid in vinegar is volatile and the citric acid in lemon juice isn't, if you used enough, it just might retain the acidity. Plus if it does and you make a salad bowl from it, you would be halfway to salad dressing!
Re: American Holly
Re: American Holly
Mac Ray
Here in Maine we get a quart of name brand concentrated lemon juice for a buck......it doesn't take much to spray the wood down with it...certainly a good piece of holly saved is worth the few cents it takes to spray it....
