ADVERTISE HERE - FREE TRIAL
Faceplate fun.....
Faceplate fun.....
Faceplate fun.....
Brian Roberts
Made a batch of aluminum faceplates from scrap.
Cut usable pieces from scrap fixture plates, programmed to cut in machining center, tumbled, and anodized. All thread milled to 1-1/4" x 8 TPI to fit the 3520b spindle.
The largest has a remnant on the edge of what was a hole in the original fixture....oh well....tried to miss all the old holes but sometimes it's difficult!
Fun projects!
Re: Faceplate fun.....
wow they look great. They have the features I like. Counter sunk holes on the face side, lots of holes, rings to help keep it from slipping, a good finish and flats on the other side to lock it down and remove it.
Keith Tompkins
Keith Tompkins
Nice work!
David Gilbert
Those are really nice. Any thoughts about going into the faceplate business????
Cheers,
David
Brian Roberts
Thanks all....for the kind words!
Having access to the CAM program and the machines is pretty cool .... always learning something.
But I have learned that doin it for fun and doin it for a living are quite different animals.
Once I had the first program done...and proven...for the 4 inch faceplate it was pretty simple to alter for the other sizes....and to make multiples of each.
It took nearly as long to salvage usable pieces from scrap fixture plates (two inches thick by various dimensions...and full of holes from their prior purposes) as it did to machine the the faceplates.
Next project....riser blocks to increase the swing of my old Powermatic 45.
Should be interesting.......
Philip Duffy
Any of those beauties for sale?..
Lyle Jamieson
Lyle Jamieson
If I remember correctly the old PM 45 has a 1 inch spindle. If I am right the spindle will be the weak link and the riser blocks will let you exceed the capabilities of the spindle. Could be frustrating
I added riser blocks to my Old J-line lathe that had a 1" spindle and 12" swing. It worked pretty well although I don't think I ever put anything long and heavy that would tend to tax a 1" spindle. Worked great for large platters.
Lyle Jamieson
Lyle Jamieson
I agree John. Just want to share my experience. I built up an old lathe and what did I get?? An old lathe with limitations I did not know existed before I put all the time and effort, and expense to try to upgrade. Still had reeves drive, still could not use at low speeds, still didn't have reverse, Still had poor fit and finish, still had a tailstock that was not lined up with the headstock. If fact way back then as a newbie, I replaced the bearings needlessly because I was getting vibration, when the problem was the 1 inch spindle that was the weak point.
Brian Roberts
The 45 is indeed a 1" x 8 TPI spindle.
You are right....it is quite possible to exceed the designed capacity of the spindle and bearings.....
Of course Powermatic really doesn't give a spec. for the load capacity.....well...other than the fact that they sold an outboard turning rest for the lathe...and touted it's ability to turn large items on the out board spindle.
Strangely..... they put a much smaller bearing on the outboard end of the spindle.....where it could be expected to sustain much higher loads than the inboard bearing.....go figure.
I have had the 45 for many years and maxed it out for diameter in the gap while turning platters and clock frames. An extra two inches would be welcome. With the riser the swing over the gap will be 20 inches. (yeehaw!!!)
The biggest downside to the 45 is the excessively high "low speed" for the step pulleys. While the Reeves drive version went from 350 to 2800 rpm (still too fast at 350 rpm) the step pulley model had speeds of 915, 1380, 2150, and 3260 rpm. 915 rpm is BLAZING fast when spinning an unbalanced chunk of ....well....anything!
I am converting the 45 to a variable speed...with a VFD and will leave the step pulleys in place to allow for changes in "power" along with the speed. I plan to install a simple Hall effect sensor for triggering an rpm indicator so it will display true spindle rpm .....not motor rpm.
And then.........sell it to help pay for the 3520b I bought recently!
Anyway....sometimes I think I have as much fun with the projects as I do using them when they're done!
Brian Roberts
Sorry....can't.....but thanks for asking Philip!
Part of the....kind of unwritten......deal is that we can use the shop at work but really can't expect them to subsidize a "business venture".....tempting as it would be.
Lyle Jamieson
Lyle Jamieson
After all that work I hope you can get a good price for it. Its still an old lathe...
Brian Roberts
Awwww...dang....and I thought it would turn into a new one....did ya hafta spoil it fer me?
Outstanding!!!
Nice!  I think you will have enough for a while!
Jim K from Trappe, PA
I have one, but sometimes wish I had two!
Thanks!  It's nice to have several....and
Brian Roberts
a few to give to friends!
