Correcting runout of chuck (Long)
Dennis in Southern Oregon
A recent thread addressed the consequences of using a chuck whose jaws were offset slightly from the spin axis of the lathe spindle. As part of this thread, a suggestion was made that the chuck jaws can be realigned by slightly loosening the screws, tightening chuck firmly, and then retightening the screws.
It turns out that I have a Vicmark chuck on which I had installed pin jaws and which ran just a bit off center. I thought GREAT, I will fix things. After a major battle to remove one seized screw, I carried out the procedure and lo, the offset was far worse! I scratched my head for a minute and then realized that merely tightening the chuck before tightening the jaw screws would only insure that the jaws would seat on a common circle, but that the center of the circle would not necessarily lie on the spin axis, depending on the nature of the looseness that allowed jaw movement in the first place.
My solution was to move the tailstock up so that the threaded stub on the Oneway live center could be clamped in the pin jaws. Then, with the jaw screws slightly loosened, I tightened the chuck onto the stub, and retightened jaw screws. The results obtained seemed perfect. This will work, of course, only if the tailstock is accurately aligned with the headstock, as mine is. On the other hand if they are not well aligned then the question of alignment of the chuck jaws is moot.
For chucks with larger jaws, the same general approach can be used, but some other method for referencing the tailstock would be needed. One possibility would be to turn a disk between centers just a bit larger than the minimum jaw opening of the sick chuck. It could be then clamped into the chuck with the jaw screws loose and the tailstock center brought up into the previously established center divot to force the jaws into alignment, after which the jaw screws would be tightened.
My method of checking chuck alignment is as follows: I turned a cylinder of about 2-inch length and diameter from a hard wood that will resist deformation by the chuck jaws. Then I turned a tenon on one end of this gauge to fit in the chuck jaws and faced off the other end to give a flat smooth face. I chucked the gauge and made a reference mark at the Jaw #1 position. With the lathe turning, and using a sharp pencil resting on the tool rest, I scribed a circle on the end of the gauge. Then, I remounted the gauge with the reference mark at the Jaw #2 position and scribed another circle of slightly smaller radius. I repeated this process with the reference mark opposite each of the remaining jaw positions. If all circles are concentric you are done. If they are not you have a direct indication of how much they are in error.
Dennis
