Vicmarc make "shark jaws" too ...
Geoff Whaling
I've used mostly Vicmarc & Nova & much prefer the Vicmarc dovetail jaw system. I own but do not use Vicmarc’s shark jaws as “shark jaws.”
Interesting that turners do not realize that Vicmarc also have a very good range of chuck jaws, including shark jaws (stronghold equivalent),
http://www.vicmarc.com/downloads/Vicmarc%20Cat%20A4%20web.pdf
http://www.vicmarc.com/downloads/4%20Jaw%20Chuck%20Manual%20Aug%2010.pdf
Shark jaws available as
VM90/100 - 48,55,74 & 88 mm
VM120/150 - 55,68,83 & 130 mm
Std dovetail jaws,
VM90/100 - 50,70,& 100 + step & multi jaws.
VM120/150 - 68,105,128,148,173,198, & 223 mm + step & multi jaws.
Doc Green's advice is very good, however I would like to make a couple of points -
- maximum holding power does not come from using a jaw set at maximum extension.
- maximum holding power does come from using the jaw size matched to the appropriate tenon size for the bowl when the jaw set is near its original manufacture diameter (perfect circle) with allowances for some compression of the tenon or recess.
- my personal experience is that making a crisp well made corner from the dovetail to the face is more important than perfectly matching the dovetail taper. This is the registration face for the jaws/bowl. A poorly cut face permits compression which then generates wobble or loose jaws etc.
-I prefer to cut my dovetail taper slightly mismatched (steeper), or slightly oversize on the base diameter of the tenon, this compresses the base slightly more than face and draws the tenon/blank down onto the face of the jaws.
- it is not safe to cut the tenon dovetail taper "under size" i.e. "flatter" or the tenon base diameter smaller than the matching diameter of the jaws. This generates vibration.
- on Nova dovetail jaws with the two bevel system I like to cut a slight relief on the micro dovetail to prevent generating a crack.
-Vicmarc’s shark jaws can be used as what I like to call “extension dovetail jaws.” Check out the design of the face of the jaw set. It is a dovetail jaw just offset from the chuck body and is very handy in some applications.
As an example the standard jaws supplied with a VM120 will grip a tenon from 38 to 85 mm however the 105 mm jaw set will have a much stronger hold/grip on an 85 mm tenon than the 68 mm jaw set. Proven!
This is where most turners have problems with dovetail jaws - they simply do not understand the properties of wood or the mechanics of jaw gripping power and actually use undersized jaws on large tenons.
I have suggested to Marco Verrecchia that they change the wording in the Chuck Manual from "+37 mm for max grip, - 3 mm min grip" to "+37 mm for max exten, - 3 mm min exten" to over come the confusion about maximum gripping power / strength.
PS Nova have a good explanation on page 12 about how to overcome the jaw run out issues some users have with jaw sets.
http://www.teknatool.com/products/chuck_accessories/Jaw_Sets/downloads/Accessory%20Jaws%20Manual.pdf
