Cherry Salad/Fruit bowl
Dominic in Bucks County PA
Here's a Cherry Salad/Fruit Bowl I just finished up. This is for my little sister. Since she was the last one to move out she never really got a Salad bowl back when I was in "production mode". This wood came from a HUGE Cherry Tree that Bill Grumbine helped me harvest back in 2003-2004. I think this is the last piece I have from that tree. I remember that day because we had to lug all that wood up a dog doo encrusted hill! :D :D :D
Dimensions: 13 3/4" dia x 4" deep with a 5" dia base and 3/8" wall thickness
Finish: Because the end grain was giving me fits, I ended up wet sanding to 600 grit with 50/50 Mix of Mineral Spirits and Spar Varnish. This mix stiffens up the end grain and allows it to shear more cleanly. The resulting swarf also fills the pores and makes for an ultra smooth finish.
After wet sanding ( and repeated clean up with mineral spirits) it was allowed to dry for several days and then sanded with 600 grit again. Followed up with 2 coats of Watco's Danish Oil (sanded between each coat). Buffed with Beall Buffing wheels (Tripoli, White Diamond, & Carnuba Wax)
Re: Cherry Salad/Fruit bowl
Sergio
I like the classic shape for an utilitarian bowl but...I will never put those chemicals on it. Yes I know, once they are dry they are safe. This is the general consensus, but I'm not in the chorus.
Barry L Elder
Mighty fine example of a cherry salad bowl. Contrary to what Sergio thinks, most of us don't eat the wood, just what is put in the bowl. (Had to clarify that a little!) :D
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Stunning in all accounts my friend!
Take care, Jim
Nice bowl, Dom...
GaryG in MD
...and great finish. ...GG
Very nice!
Dick Coers
For some folks, when they look that good, they will never see a salad. I prefer a light film finish, usually a low sheen.
Alan Hollar
Every finish is chemicals. Some grow, some are synthesized, some are mined. If you could chew off the described finish from a dozen bowls in one day you might ingest enough of the drying salt to create a mild nausea. Meanwhile, the wood that came along with the chemicals would have a more profound effect.
Tony Rozendaal
That's a gorgeous bowl with a great finish - thanks for sharing your process on the finish.
Beautiful!
Dale Jablonski
Dale Jablonski
Beautiful job. She will treasure this. You do tend to remember acquiring wood like that. :D
