Casting resin *LINK*
David Walser
Australian Brendan Stemp, on his Youtube channel, shows how he uses epoxy resin to make turning blanks. He makes fairly large blanks -- such as pepper mill blanks and bowl blanks. He uses Solid Cast 606 resin, from Solid Solutions, for casting his blanks. An advantage of the resin is its relatively long open time, which allows the time needed to pour larger blanks. Also, the long open time allows any air bubbles to migrate to the top of the resin before the resin hardens. This avoids the need to cast the blanks under pressure. Also, the resin does not produce a lot of heat when hardening, allowing larger blanks to be cast. (Sometimes Brendan uses two pours for a blank to avoid the excess heat that would be generated if a really large blank were cast at once. To do this, he pours half the blank and allows it to set up but not cure completely before pouring the second half. This approach produces a seamless blank.)
I don't believe Solid Cast 606 is available in the USA. Question: Can any of you recommend a resin available in this country that could be substituted for Solid Cast 606? The bowls Brendan produces are spectacular and I have a lot of off cuts that I'd like to use up.
Making bowl blank with scraps of wood and resin
