Power carving wood???
Ron Bauer
Do any of you carvers use the high speed dental hand pieces that can be found on the "bay"? They are called NSK type. I am concerned about the torque relative to the pencil type hand pieces that are often shown in the power carving videos. I understand that none are real hogs but they do need to have a little power. I am talking about carving, not piercing. TIA for comments. Ron.
Re: Power carving wood???
Lyle Jamieson
Lyle Jamieson
From my experience the high speed dental hand pieces are good for piercing and piercing thin walls so there is little resistance. They will not be good for much carving. They would work well for cleaning up details or undercutting relief carving. More power and less speed is needed to carve much wood away. I do all my figurative sculpture carving with rotary carving tools. I use air powered die grinders with burrs and Foredom with rotary cutters and a variety of other bigger equipment like angle grinders with Arbortech cutters.
The dental hand pieces that run at 350 to 400K toms don't have any torque and are designed for. Dry thin burrs only. Shallow gunstocks carving and piercing are what they are used for. I use the Dremel for deeper carving than the NSK stye carvers. I step up to the Foredom for heavier stock removal and then go to air die grinders or electric angle grinders for serious stock removal
Mark Wollschlager
If you mean the micro-motor hand pieces, for instance the RAM or OZ plus units treeline sells, or the micro-pro from mastercarver. Then yes they work well. they use 1/8 or 3/32 bits up to 50K rpm.
The more money the higher quality of the motor and bearings.
The smoothness and noise level of the OZ versus the ram/micro-pro is very noticeable. You are going to be holding one of these for hours and it makes a difference.
You can use any of them to remove bulk material, but it will wear the unit more.
A dremel, foredom, or die grinder will remove.
A lot of those cheaper 'bay handpieces are made for polishing dental stuff, crowns ,dentures, some are made for nails.
They would not last long carving wood.
Ron Bauer
Thank you all for the comments and suggestions. Ron.
