How bad do you want it?
steven antonucci
For starters, you can make your own or just buy them from the knife supply catalogs (Texas Knife/Jantz). The more involved they are, the more they cost.
If you want to make your own, you need an assortment of stuff (various wires and tubes), and colored epoxy. If you make your own, it can be any diameter you can imagine... and any material. (various wood metal combos?)
Once you have a rod made, you'll want to use your chuck to accurately drill the end for the rod. You can use colored epoxy to set it in. depending upon the diameter of the rod, you can reverse it in the chuck and hold it in a small set of jaws or a drill chuck to finish turning your handle.
