Veritas - Innovation in Tools
help!
help!
help!
GaryG in MD
OK, all you machine-heads... here's your chance to shine.
I have good weather tomorrow, but the drive on my trusty Jet 1236 has started slipping, after 12 years of use.
It started at the high speeds, which I rarely use since I don't turn many spindles, but it has worked its way down to the lowest speed now, so it's time to fix it.
I took the cover off for the first time, and what's inside is almost laughable!
Except, now it doesn't work right.
OK, so it's a Reeves Drive -- a form of CVT. Cool.
According to the web, with that kind of thing, both ends are supposed to vary their width on the V-belt at the same time to maintain belt tension. Well, I guess that must be the problem, because when I move the speed control handle to higher speeds, the belt just gets loose. Definitely not effective!
The tailstock end of the variable-width pulley on the handle end moves toward the tailstock, as I assume it's supposed to. Nothing happens on the motor end. Quite frankly, it's not clear to me how it would, but I never took a look at it when it was working right (my bad), so I haven't got a clue what's supposed to be happening that's not. There's a spring out there, but I don't see any way for the pulley width to change. As a result, the belt just gets extremely loose as I try to go to higher speeds. Whatever is supposed to keep it tensioned is not happening. And now, the tension is not enough even at the slowest speed. So I'm out of action until I get this thing fixed. Not a happy camper. I'm in the middle of a lidded cherry box for Beads of Courage, and I don't want to stop!
So, please tell me what exactly is the problem, and what I need to do to get it freed back up so it will work again.
And we thank yew fer yur support! ...GG
Re: help!
Re: help!
ben d.
The is an outer spring on the motor shaft that compresses the pulley in when going to higher speed and when the speed handle is moved to slow down the speed it goes the other way. The one on the handle is controlled by the lever so it is going to move , may be stiff but it will move.
Look on the motor shaft end and there will be a snap ring there remove it and the washer behind the snap ring and the spring will then come off, remove the outer pulley and clean it up put some lube on it slide it back on and it should work fine. Be sure to look and see if the inner half of the pulley has moved in toward the motor, if so it will have to be brought back to the original position and held in place by a set screw. If you are not sure if it has moved loosen the set screw and pull it back and find the original set screw indention and position it there. It is a good idea to use blue locktite on the set screw to keep it from loosening. Check the belt condition and might be a good time to replace it if it is frayed as that makes a difference in the speed range. O Riley parts store is where I buy my belts at.
I have a 1442 and this is the same set up and have had it apart a number of times.
To get the snap ring off use a pair of vice grips on the washer and push in on the spring to remove the ring and re-assemble the same way.
Hope this helps you out.
ben d.
Re: help!
Caution:  Spring!
Doc Green
If the spring is anything like the one on a Sears Craftsman Professional lathe, be careful with it. It is powerful. Try to find a way to secure it before you set it free. Also, give some thought to how you are going to put it back together.
On the Craftsman, the spring is mounted on the pulley for the spindle. I ran a threaded rod through the spindle and used it, with suitable fixtures, to compress the spring. Once the clip was removed, I could ease the tension off the spring slowly.
I had to loosen up that pulley about every three months or so. Tried every lubricant in the world, and finally found the best lubricant was none at all. I hope you have better luck than I did.
~Doc
Re: help!
Re: help!
Chuck Engstrom
Hi Gary -- Reeves drive components are supposed to be moved only while the motor is turning, but I'm sure you know that already. I put link drive belt in the one I had (pretty much the equivalent Delta) some years back, though I don't know if that really brings anything to the party. If the parts are not sliding on the shaft to effect the change of diameter, one of my friends recently sent an analysis of penetrating lubricants which found 50/50 ATF/acetone the most effective, and that or other lubricant may get it moving again.
All that said, my experience with Reeves drives has not been entirely positive, for much the same problems that you are experiencing.
Cheers! -- Chuck
Re: help!
Re: help!
Brian Roberts
As others have said, It likely just needs cleaning and the proper type...and amount...of lubrication.
Once back to proper operation it is important to "exercise" the drive by running it back and forth..... from highest to lowest speed several times. I would do so at least once a month....whether you use the highest or lowest speed in your turning or not!
The exercising really keeps things moving as they should.
Best of luck!
Brian
Re: help!
thanks Ben, Doc, Chuck, and Brian
GaryG in MD
I'll see what I can do.
I hate springs -- never did brakes on my cars for that reason.
At least now I know the basics.
Thanks all, GG
Re: help!
the spring...
GaryG in MD
Ben,
Your explanation was very clear and helped me a great deal in understanding how it's supposed to work. Thanks very much for that.
I appreciate your experience, but per Doc's comment, I'm very uncomfortable around big springs.
You say to just push it in by hand. I'm not sure it isn't too strong for that?
What's going to stop it from being dangerous when the clip is removed?
Can it be compressed manually (easily) to reinstall?
I would appreciate it if you could give me some feel-good words -- or more-detailed, step-by-step instructions that are safe for a novice.
Thanks, Gary
Re: help!
about the lube...
GaryG in MD
May I assume that things like WD-40 and silicone spray are not good to use for this application? Or might they be a good way to try to free it up on the shaft without taking it all apart?
What about Marvel Mystery Oil (Panther Piss)?
Thanks, GG
Re: help!
inner pulley location
GaryG in MD
Ben, The inner end of the inner pulley half on the motor shaft is as close to the motor housing as it can be without touching. But it's not touching. Do you think that's where it's supposed to be? I have no reference for knowing. I don't want to move it if it's where it's supposed to be (don't fix it if it ain't broke!). ...GG
Re: help!
photo of pulley locations
GaryG in MD
With the lever in the high speed position, both halves of both pulleys are pretty much lined up parallel. The belt is very loose. The "teeth" of the motor shaft pulley halves are just barely engaged. They should be tight together. So which half of the motor shaft split pulley is in the wrong location? ...GG
Re: help!
Re: photo of pulley locations
Brian Roberts
Hi Gary,
I have looked at a parts blow up ...online...of your lathe.
IF IT WERE ME.....I would use some "paraffin base, non-gumming, high quality lubricating oil" ....such as:
http://www.ebay.com/itm/Turbine-Lubricating-Oil-with-Zoom-Spout-High-Quality-All-Purpose-Oil-4-Oz/121603524564?_trksid=p2054897.c100204.m3164&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20140407115239%26meid%3D3b2d847fcd0c4738a20b31bcc046178c%26pid%3D100204%26rk%3D4%26rkt%3D30%26sd%3D201266736501
Extend the spout and put 3 or 4 drops on the shaft that the moving half of each pulley slides on.
Put one or two drops on each side of the sliding portion of the pulley....making sure you get it only on the shaft and right up next to the pulley ....the objective being that it "wicks" in between pulley and shaft.
Work the lever back and forth and it will (should) free things up. Be patient and start with a drop or two.
Have a look at the parts diagram so you may better understand how the parts relate....
Best of luck....it's really not complicated.
Brian
Re: help!
Re: inner pulley location
Brian Roberts
Is the set screw loose?
If so...the pulley may have moved.....if not...not likely.
Re: help!
Re: the spring...
Brian Roberts
Gary....
Looking at your photo....
Pull right on the right half of the motor pulley....LATHE UNPLUGGED...with your hands. Does it move?
Push left on the left half of the upper (in your photo)....does it move?
It should be fairly easy to move each to the point where the springs are fully compressed....which are not in your photo.
If they both move ....move on to my post about lube......
Brian
Re: help!
Brian Roberts
The link in my previous reply should have...but doesn't...taken you to an example of an oiler...with proper oil.....on Ebay.
Do a search on Ebay for item #121603524564.
I have no connection to the seller.
Re: help!
Re: about the lube...
Brian Roberts
See my reply further about non-gumming oil.
Re: help!
Lyle Jamieson
Re: help!
Lyle Jamieson
When you take the belt off the pulley should slide in and release the pressure on the spring. Be sure to replace the belt. As it wears over the years it changes the speed range and needs to be adjusted to compensate for the worn belt.
Re: help!
Re: help!
walta
In my opinion spray on stuff is general a temporary fix, that makes the real a dirtier and more difficult job.
The fact is Reaves drives require regular maintenance. This means they must be disabled and cleaned.
As the belt wears the bits of rubber always seem to find their way to shaft preventing the pulleys from moving freely.
It seems a lot of people have used excise force in steed of maintenance. Damaging the pulleys please note at this time 2 of the pulleys are no longer available. So please be careful not to damage the ones you have.
Walta
Re: help!
Brian and others...  continuing...
GaryG in MD
The problem is with the pulley on the motor shaft.
The half pulley on the motor end is screwed onto the shaft in a position that may or may not be correct, but I have no reason to believe it is not correct.
I believe that the problem is the half pulley on the outer end of the motor shaft, where the spring is. I am unable to move it in either direction. The "teeth" are just barely engaged with the teeth of the inner half, so I'm guessing that it should be pushed closer together by the spring. But the outer half pulley is basically frozen on the shaft -- won't go either direction.
Now what? ...GG
Re: help!
Re: Brian and others...  continuing...
Glen Key
Gary this might be a dumb question, have you tried compressed air? I'm thinking of blasting with an air gun to see if anything breaks loose. Always worth a try.
Re: help!
Brian Roberts
Did you try the 1 or 2 drops of oil like I suggested?
If not....do so.....and let it sit for a bit while you try to loosen it by hand....wiggle and pull.
Pull hard toward the spring on the outer motor sheave.....with both hands....with your third hand tap on the end of the shaft with a plastic/rawhide mallet to help "convince" it to move.
It takes some effort to undue years of neglect.....dig in my man!
Re: help!
Have you been soaking it?
Dick Coers
With the good stuff like Kroil, or PB Blaster. Not the water displacement spray. I think you are dealing with either aluminum or pot metal, and there could be some galling. I recently worked on an industrial reeves drive. The motor side came apart quite easily, but never did get the head pulley apart. Luckily the motor side was the issue. I'll still work on the shaft side soon, but if it works......
Re: help!
Got it!  Thanks, guys!
GaryG in MD
I was able to break the outer half of the motor pulley free!
I needed a spray to get into the nearly inaccessable area, so, against recommendations, I decided to use a copious quantity of WD-40 as a penetrating oil and sprayed it into the shaft area where the rim of the stuck outside half rides. With that and a little persuasion with a 1/4" wooden dowel between the halves, I broke it free. Woohoo!
OK, now the question is do I try to lube it in place or do I pull off the keeper and remove the outside half for a good cleaning.
The latter is clearly called for, but I'm afraid of that spring -- both getting it off safely, and getting it back on again.
We'll that's enough for now -- got to do my taxes!!!!
Thanks again, everyone, for all you help. I really appreciate it.
And, yes, you can believe I'll be MAINTAINING it properly from now on!
...GG out!
Re: help!
Re: Got it!  Thanks, guys!
ben d.
Glad you got it that far. Freeing up with wd 40 was good but it will be a temporary fix. I would suspect from the amount of engagement of the pulleys that the inner pulley have half has moved toward the motor a little also. The spring is not that stout and compresses easily, just clamp a pair of vice grips on it and I just push in with my belly and remove the clip and release the spring and go back with the same method unless you have someone else to hold it for you. Remove the set screw in the inner pulley and slide it out and you can see where the original set screw mark is on the key and slide it back to that position and replace the set screw and tighten it up with some blue Loctite really tight to keep it from coming loose.
The pulleys are aluminum and the outer pulley will have some lube or grease groves it, when you get all the crud cleaned out use some good gun grease to fill it up and when you slide it on all the grease will be pushed out except what is in the grooves, wipe off all excess replace the spring and belt and you should be good to go. Jet uses a special grease gun to lube the pulley, if you notice the little ball in the end of the motor shaft it is depressed to grease but we cannot do it this way so the above.
If you want to prolong this happening again look at the gap between the belt pulley shield and you will find it is quite open and the fan from the motor is blowing the dust in there and it mixes with the lube and cruds the whole thing up. Get some foam weather stripping adhesive based and stick it around the motor and frame and close the dust entry off, I did not stick any to the cover itself.
Be sure to clean out the lathe head while it is all uncovered.
Re: help!
Thanks, Ben.
GaryG in MD
This is exactly the kind of practical info I needed.
I think I'll be able to handle it now.
Good show.
You've been a big help.
Thanks, GG
Re: help!
Re: Thanks, Ben.
Jorge
Gary,
After 12 years, is a good idea to give that lathe a new belt.
