Member Galleries
Member Galleries
Member Galleries
William Duffield
Reference the related post in the main Messages forum.
Re: Member Galleries
Dennis in Southern Oregon
William, I suggest that you republish this directly to each of the message boards. I have been a WC'er for several years and did not know ihat there was a "main" board. I agree that from what I can see activity in the galleries is low. However, it is not zero. I opened a gallery with several pieces this month and received comments from several members. I believe that this resource deserves to be promoted more actively. There is a lot of inspiration to be found the galleries, and it is easy to start one's own gallery.
Re: Member Galleries *LINK*
William Duffield
Dennis, I'm not going to tell you I'm sorry I caused you to do a little discovery. I shouldn't have called it the "Main" Message board, however, especially to a bunch of Turners. :D It hadn't occurred to me that someone wouldn't know where "Messages" is located, but then I regularly visit all three of the most used boards, because I have lots of hand tools, lots of power tools, and even a couple of lathes. I hope others here will go explore the Members Gallery for some of your beautiful work.
To browse the galleries: http://gallery.woodcentral.com/all-gallery/
Instructions, so anyone can sign up to display their work: http://gallery.woodcentral.com/
Here's the message, with a link to the Article itself:
We've noticed that not much is happening on our newest feature, the Member Galleries. I don't think anything has been contributed, not even a comment or a new member registration, in weeks.
So, I decided to stir things up a bit, and being cantankerous, instead of adding something, I deleted something.
If you hadn't seen it before it disappeared, Don't Panic! It was a construction methods description related to a piece of Federal furniture that I had previously posted to the gallery. Ellis and I discussed it, and we decided it was definitely in the wrong place, so we moved it to the Wood Central Articles and Reviews section. It's still at the top of the list of new articles, so you can still find it if you look.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=newarticles&file=articles_953.shtml
I may add a couple of pieces a little later, but I don't think they'll be as interesting as my first two.
If you do ever need to delete an image from your gallery, first select your gallery by scrolling through the page of introductory gallery images until you find it. Click on your gallery, and you will be shown a page of gallery entries. At the top of the page, click on "UPLOAD IMAGE". Now you will find a "Delete" button at the bottom of each image, which you can click if you want the image to go away.
Let's see what you've built.
Stuart Johnson
Part of the problem is we see recent comments and recent galleries created but not if there is an addition to a gallery. Unless I'm missing something the only way to determine if there is something new is to open each gallery and look at what has been posted.
Re: Member Galleries: a question
Sergio
I uplod very shrp images but once uploded they loose a lot of details and cannot be expanded without losing details and perhps focus. Am I doing something wrong?
Send me a copy
Sergio, your images should not be deprecated when you upload them. When you click on a thumbnail in your gallery, it should open an 800 pixel wide image in a box in the middle of the page. Clicking on this image will open the full size image. That one should be exactly like the original you uploaded. If not, send me a copy of the original and I will look into this further.
Ellis Walentine, Host
Re: Send me a copy
William Duffield
The details may depend on Sergio's browser. I was just looking at some of his high resolution images. When I click on the 800 pixel image, it shows up in a new window, but the window is the same size as the previous window I opened, and the image is still shrunk to the size of the window. I have to click on the new image to get it to expand to full size.
Re: Send me a copy
Sergio
I'm not too expert. So what do I have to do to improve the resolution? I'm now using Safary on ipad.
Re: Send me a copy
Sergio
I click the thmbnail and i get an image larger but nit detailed. I click on this image and get a much better one!
Exactly!
Sergio, our gallery software takes your giant image and compresses it to fit in the little popup box. That process is not a true resize, and it results in a certain amount of image degrade, depending on how big the original image is. If you upload an image that you've resized to 800 pixels, there won't be any compression needed, and the image will look better. When you upload a giant image, you don't get to see the detail until you've clicked through to the final size, as you've already noted.
Ellis Walentine, host
Re: Exactly!
Sergio
Thanks
