Finished #2 in this series. I did use mineral spirits to sand. But instead of throwing out little strips of gummed up paper, now I have slurry and goo on the paper and the lathe. Not much of an improvement! New one is taller, the post is more refined, and a slightly different taper on the cross pin. Comments welcome, especially on the comparison.
I like them both very much, but you definitely improved the breed with the second, taller one. The box part and the knob and the pin all have a better curve to them.
Oh, did I forget to mention the painter's drop cloth over the lathe, and another one to make a tent to protect the rest of your shop.
I have a couple of old rich pine burls that have been laying around for 30 years that I keep putting off turning. Some day though, I'm going to do something thin, then saturate whatever portion isn't already with CPES, to see if that makes it even more translucent, and perhaps easier to sand, and less flammable. I think now with some many good LED options, there are better safer possibilities for internal lighting than ever before.
Several years ago I made a side board out of heart pine. I sanded some of the pieces in my Performax. If I was careful I could run on piece through and then change the belt. Had about a dozen belts to get through the project. I woudl take one off and drop it into a gallon jug with some Simple Green in it and in few hours the crud woudl come off. Mostly. Then I would stand at the kitchen sink and scrub the rest off with a brass brush under a stream of water. I tried coating the belts with talc. Did not seem to help enough to warrant doing it. Only someone a frugal (cheap) as I am would go to this much trouble to stretch the life of sandpaper.
Some of the wood had close to sixty growth rings to the inch.
I also like the fuller curve on the taller one, but they are both very nice. I'm glad that others have mentioned wet sanding Pine with various lubricants -- probably the only way to get good results w/out owning a sandpaper business.
I have worked with a lot of reclaimed heart pine from old beams and columns out of tobacco warehouses. When you cut this wood it smells just like it did when it was cut a hundred years ago.
I have no suggestions on sanding. You just have to expect to use a lot of sandpaper. Just bite the bullet and expect to use a lot of sandpaper.
I love your boxes. I haven't seen any of Craig Lossing's work in quite a while so I was glad to hear that he is still out creating his unique boxes.
I got a little teasing today about that lathe today. I was at a sharpening service the other day, talking about custom cutters for it. I told the guy that owns the shop where it sits, and said, "Cutters? At the rate you are using it, those existing cutters are going to last a long time!" Chips will fly soon!
I found out this building was built in 1930. So maybe that window sill was outside for 85 years? Taking off 1/16" off the outer surface, and it looks like this. Some checking in some places, but I'm still going to us it. They help tell the story of it's history.
I just had the thought, what does it mean when a woodturner has every square inch of space filled with figured wood and burls, but still gets excited about an 85 year old window sill. MAN I HAVE IT BAD!!!!!!!!!
