Steady rest advice. Please.
Sergio
Hello all, I'm thinking of buying a steady rest for a 24 inch lathe for use on hollow forms etc. I'm considering the following three that, unfortuntely I have no possibility to see in person. Of course I might consider another one if recommended.
Carter: made of aluminum is it stable? The possibility of various positions of the wheels and of the rest itself are attractive, but I'm afraid it can be prone to vibration and instabilities.
Then The Sinner and the Robust: both seem strong andthe price is close.
I would appreciate the opinion of somebody who have real experience on them.
I'm not interested in the Oneway, I had it and found cumbersome to set up, I sold it.
Thanks for your insights.
Re: Steady rest advice. Please.
Robust
Jorge
Sergio,
I love my robust tool rests... well worth the money
Chuck Engstrom
Hi Sergio -- Think about building your own. Make it from a glue-up of a couple of layers of 3/4" ply or a hunk of extra thick lam-beam type scrap from a local builder. Wheels available from skateboard/rollerskate shops. Square steel tubing for the arms available at Lowes/HD. You'll save several hundred dollars and have something just as solid.
I haven't done this myself but I do have all the parts, just haven't needed to get it done yet. There are several sets of plans on the web.
Best wishes -- Chuck
Dick Hines
Dick Hines
I built a steady rest. It worked good but was a pain in the butt the move. I now have a Carter. Very to set up and move along a piece as I work toward the bottom.
Not cheap but I find it worth the money.
david delo
I have the Carter Multi Rest in the 20" version for a 3530B and it's rock solid. Yes a little pricey but if your on their email list you can get 20% off when they have their sale. I've only used it as a bowl steady rest 1 time for a piece of walnut I just couldn't get to balanced very well. For the large mouth vases I've been making, blank sizes have been 16-18" with a 12" deep hollow and it's worked great. Good luck with your decision.
Advanced Lathe Tools / Steve Sinner
Joe Meirhaeghe
I have one from Advanced Lathe tools / Steve Sinner. I've been using it for 5 or 6 years now with no problems. It's built heavier duty than most. He uses much larger heavy duty bearings & harder wheels than several others. The harder wheels transfer less vibration than softer skate type wheels. I believe there also made of 3/8" thick steel if I remember correctly. I've used it to hollow vessels weighing over 200 lbs with no problems. If you have any questions just give Steve a call he's always glad to talk to anyone with any questions about his products.
Now for a little disclosure I work with Steve turning vessels at his studio on a regular basis, but I have no financial interest in his tool business. Just letting you know I use his tools on a regular basis in his studio & also at home in mine.
Ron Solfest
I have used and liked Robust rests for a number of years, I now have 3 of them. I'd recommend them. With that said, not sure if you're looking for more complicated ones with bearings for hollow forms than I have experience with.
Sergio
Yrs I really intent steady rest to hold hollow forms, not rests for banjos! Thanks for your answer, it looks like all three I mentined work fine. More confused that before. It would be nice to just walk in a store and check them out.
Ronny
just come and have a look at the Carter multirest at work next time you are in Belgium....
Sergio
Thanks, I go to Antwerp almost every two weeks. Where do you live?
Re: Advanced Lathe Tools / Steve Sinner
Mike Foster
I have a Robust lathe and bought the Robust stady for it. I have one built out of plywood (2 pieces of 3/4" glued together) but they just don't have the stiffness of the steel steadies. I sometimes use both on the same piece. If I were to buy one now, I might consider Steve Sinner's as he has thought things out just a bit more. The one thing I like about Steve's is that the top wheel is offset which keeps the steel that holds the wheel out of the way when using a laser pointer. Don't get me wrong, I love the Robust steady and have no plans on switching it out.
Jeff Smith
If you've got the patience and a welder, you might look at making your own 'Nichols" Style Steady rest. I made one for the AB from the excellent plans/tutorial that J.D. Combs put together. It uses an angle ring from McMaster Carr - I think the total cost for everything I bought for it was right around $75.
I 'adjusted the plans for my own tastes - angled the wheels by 7 degrees to get the top one out of the way; mounted 3 wheels rather than the 4 the plans called for.
It works great and is solid as a rock. Still got the plans if you're interested let me know.
Sergio
Thank you for the plans but I'm not a welder. I need something on the market.
Ronny
Hi Sergio,
I live in Geel, that is about 40 km east of Antwerp, via the E313 which has an exit there.
You are very welcome.
regards
Ronny
