200+ woodworking book reviews
Worms (larva)
Worms (larva)
Worms (larva)
Hal Taylor
Not really turning, but I just got a call from a friend who has an antique piece of furniture that worms have burrowed in. Knowing we turners oftentimes have the same problem thought I would ask here. Obviously, a piece of furniture is too large to microwave, so how does one get rid of the buggers?
Re: Worms (larva)
Re: Worms (larva)
Put it in a bag with moth balls inside for a few days
Re: Worms (larva)
Dale Jablonski
Re: Worms (larva)
Dale Jablonski
Or they could contact their local pest person. Moth balls may not kill the pest. Is it larvae or carpenter ants?
Re: Worms (larva)
Mike Stafford
Re: Worms (larva) *LINK*
Mike Stafford
You are not specific as to the species of insect you are finding. Larvae are the juvenile form of an insect. The eggs are laid on the wood, hatch and the larvae bore into the wood and pupate. When the adult beetles emerge they bore out leaving the tiny little emergent holes and fine powdery dust that alarms us when we find it in our timber and furniture. Most of the boring holes done in furniture are done by the adult powder post beetles as they exit.
Here is a good article about how to treat for a powder post beetle infestation. If the beetle infestation is in furniture it is recommended that the fumigation necessary to eliminate the insects be done by a professional as only a professional can legally obtain it.
Powder Post Beetle Control
Re: Worms (larva)
Re: Worms (larva)
Hal Taylor
Thanks Mike. I don't know the insect species (nor Genus), but these are larva.
Re: Worms (larva)
Re: Worms (larva)
Ron Bauer
As a fly tier I often fight bugs. I have found that moth balls will repel insects, but paradichlorobenzene will kill them. PDB is delivered just as moth balls so it is easy to dispense. Ron.
Re: Worms (larva)
Re: Worms (larva)
Keith Newton
Hal, There are certain parts of the US that have termites which aren't subterranean, and in those areas, the exterminators will tarp the whole house, then release a gas inside, which will penetrate all the wood under the tent. I think it is methelene bromide. If this piece is within that area, the exterminator can just put this piece in the next house without much effort.
Heat is another way to kill everything inside, but you run the risk of over-drying the wood, and causing checks. However, it might be possible to totally wrap the piece with that clear wrap like used for shipping to keep the moisture in, then use a tarp to build your own tent, using a small space heater blowing into it. Search the articles with my name to learn more. you would need to get the wood up to 135º to kill everything inside.
Oh, and one last suggestion. I once harvested a big hollow Silver Maple which was full of termites except for the outer 1.5" of living sapwood. It was over 12.5' tall, because I had to take part of the metal ceiling tiles out to stand it. I sealed it with a big tarp, then set one of those Bug-bomb that you can buy at the hardware store inside, and pulled the tab. There were places 4" thick where they had tunnels that it got into. The floor was a solid mass of dead termites and carpenter ants when I opened the tent the next morning, and I never saw any live insects after that.
Re: Worms (larva)
Mike Stafford
Re: Worms (larva)
Mike Stafford
The technique that Keith is describing is commonly used in a variety of industries to destroy insects. One, in particular, is the food industry where insect infestations from eggs in the food such as grains and nuts can be destroyed by the application of heat. There are companies who now tarp houses and using an external source of heat pump in hot air to raise the temperature to kill the insect infestation.
Fumigation is more than just exposing something to a gas. The gas has to be able to penetrate to the source of the infestation. That is easier said than done. The gas from moth balls will kill or repel moths which are the adult form of the insect, but it has no effect on the larvae or eggs. Quite frequently, those items are hidden in places and protected well. And moth balls will not keep rats, mice, skunks, snakes or just about anything else away from your property.
There are a lot of beneficial properties assigned to moth balls but most of them are little more than myths.
Re: Worms (larva)
Re: Worms (larva)
David Walser
You're not going to say that dropping a couple moth balls into my car's gas tank won't increase gas mileage, are you? 'Cause, if you are, I don't want to hear it!
Re: Worms (larva)
Re: Worms (larva)
Hal Taylor
Thank you very much guys. Lots of good info I did not know, and I have passed it along to my friend.
