Re: Need advice, Clay...
clay foster
I roughed out the blanks from green beech a couple of years ago, and left the tenon on them. If the tenon gets too out of round to go back into the chuck, it can be trued up again by mounting the plate over the chuck jaws and holding it in place with the live center in the original hole.
My method for cleaning up the bottom after the plate is turned and sanded is pretty low tech. I turn a recess in a blank of wood and secure the plate in place with little sticks and screws. The plates are within 1/4" of being the same diameter. Start with the smallest plate and increase the diameter of the recess as needed. If it's a little loose, shim it with precision masking tape. If it's a lot loose, make the recess deeper.
If I were a production turner, I would probably have a vacuum chuck. But, I'm an analogue guy in a digital world.
