Re: De-humidification wood drier
Dale Bonertz
Ron, I have a lot of experience drying in a kiln like this. There have been a lot of decent ideas here but if you really want to dry 30 to 40 blanks per kiln load per month or so then what you are wanting to build makes sense. However depending on size of the blanks you should be able to dry a lot more than 30 to 40 in one that size. I just emptied mine which is 8' wide by 7' tall by 3' deep (outside dimensions) and I pulled out about 30 - 15" to 17" blanks and then various sizes from 6" to 14" and the total was around 150 blanks.
First I would not use light bulbs. I used to use light bulbs and they are a pain if they burn out during drying unless designed in for easy access. If you add the cost of the bulbs against say a heating element for a stove (about $15) the cost of the bulbs become expensive (they are good for about one load in a kiln the size you describe and you need about three per load running 24/7 to hold the heat).
If you build a bigger kiln frame it much like a house wall and insulate it with r-13 insulation. Put tyvec or plastic over the insulation on the inside then put your plywood over it. I put a double plywood base in mine with the top piece being pressure treated for all the water that it holds. Seal all your corners with a high grade paintable caulk and prime and paint the inside really good to save the plywood.
You will need a couple of fans to move the air inside it (good fans made for heat and moist air). A good dehumidifier that will not shut itself off at 105 degrees. And finally a thermostat (again a good one) to shut the heat off when temp is reached.
If you need any other help you can contact me and I'll help you through it.
BTW I anchorseal the entire blank inside and outside and depending how wet the wood is when I put it into the kiln they dry in 4 to 6 weeks. I spray the anchorseal but if your going to brush it on you can just do the end grain inside and outside.
