Robbo's next lathe *LINK*
https://www.youtube.com/watch?v=G0MPVFBEyRs
Re: Robbo's next lathe *LINK*
Mike Potts
John, I think I got you on this link
https://www.youtube.com/watch?v=qm9CljA5gyI
I wonder if Liam has thought about
Geoff Whaling
I wonder if Liam has thought about what happens if the chain on the chainsaw breaks or he has a "pull in" event if/when the saw chain grabs or bites unexpectedly?
I like seeing novel solutions but they don't have to be risky too.
Up to the 2' mark no major problems, a face shield would be prudent at minimum.
After that he lost me. Then there is the fact he is using the chainsaw slightly inclined off the vertical and cutting with the chain on the lower side of the bar (1’30” on) – a potential "pull in" hazard. The mounting of the saw may be convenient but I see very little in the way of controls to prevent the saw from being dragged forward into or along the wood, or to prevent the saw from rotating further & grabbing more forcefully. The way Liam bumps the saw mount to adjust its position seems to reinforce my thoughts. Yes the saw mount appears substantial but is it enough – I do not believe so.
The inclined saw and body position in combination place him right in the most dangerous zone he could possibly be in. I simply shudder at the thought of him even considering placing himself in that zone.
Gas & electric chainsaws are very powerful tools with lots of torque and that chain moves rapidly. I do not believe the average person could possibly react fast enough to withdraw from the line of fire if/when things go wrong. He should not be in that zone – full stop.
Simply re-positioning himself away from the cutting bar would lower risk considerably. Using a foot operated power switch may well worth introducing so the saw is stopped while he makes adjustments.
Re: I wonder if Liam has thought about
George Hurlburt
I took a class from Liam at Arrowmont week of 6/9/87. We turned platters, boxes and made tops and thimbles. Those items made from that log, would take weeks. His dark hair turned gray like mine.
Funny...
Ralph Lindberg
I'll try to remember to tell him about this tomorrow, I think he didn't bring any computer along.
Between a lathe (Robust Liberty), his chainsaw chopsaw, wood, tools, sharpening rests, etc, etc. His van was full
Joe Meirhaeghe
Liam stayed with me & spent a lot of time with me over the couple of weeks he was working on this and one other piece he did on that lathe. I questioned him frequently about safety. Some how he felt totally safe, saying he's been doing it this way for a long time & knew the possible dangers. All I can say he was way more confident than I am about standing in front of a running chain saw.
Well the saw is bolted to a stand so it isn't going to kick back. I've Brocken a chai twice and nothing happens. It just stops. So other than being careful to not touch the cutter I don't see a problem.
robo hippy
Robbo is the Aussie who did the 'why you don't use a spindle roughing gouge' video clip. Me, robo as in robo cop. Slight difference. The lathe I want is that one where they turned the worlds largest bowl by gluing up 2 x 6s and driving the tractor up on a high spot and used a wheel rim for the face plate. I could have fun with that. Not sure about the chain saw thing though. Maybe a chainsaw bit on a trick though.... Have to think about it...
robo hippy
Roy
This was obviously an Irish grind chain on the saw.
Roy
