Finishing Laser Engraved wood Pens *LINK*
Mike Brazeau
I do a few pens now and then and have a request to do have laser engraved initials done on one. Assume you would finish after the engraving? I do a plain CA finish and use micromesh and then Hut polish. Does the engraving change things at all when applying finish? Would guess a bit of light sanding might need to be done around the engraving?
The Joy of Wood
Re: Finishing Laser Engraved wood Pens *LINK*
Ric Taylor
Ric Taylor
Mike,
I have done many of those. It works best to complete the finish first and then do the engraving.
The engraving will leave a bit of smoke residue on the surface. This is easily cleaned off by dipping a rag into a 50/50 mixture of water and white vinegar to get the rag damp, and a few swipes over the engraved area.
Try it a a practice piece first so that you get the feel for it.
Ric
David Walser
Mike -- Talk with the person who will be doing the laser engraving for you. IIRC, they wanted the pen blank completely finished, but unassembled.
Good luck.
