It's on the floor, Phew!
Dick Coers
16' 6" overall length, 2,600 pounds (?) of German cast iron goodness! I know the main lathe weighs 730 kg (1609 pounds) but just guessing on the extension. I'll have to pull the electrical and give it a cleaning. Pretty tired today after that work out yesterday. I was really lucky that a steel fabricator down the street was able to help unload. They brought down 2 forklifts to get the 10' skids out of the truck. I gave them enough cash for pizza and beer for there entire crew, it was a life saver! Just can't get over the scale of this thing. The drive spur is a number 4 taper, 45 mm thread on the headstock shaft, and the template support bar is 1 1/4" thick x 3" wide steel. Our son loves German cars, this thing is probably bigger than his Volkswagen GTI !
Re: It's on the floor, Phew!
Congrats Dick, It looks great.
Keith Newton
I was trying to recall, did you say that you plan to fit it with a motorized cutter head that could speed up the rough cutting. As slowly as the larger stuff will need to turn, that is what I would be thinking.
What is the range of your RPM's, and did you get any accessories like steady rest, or special tailstock plates or anything?
Re: Congrats Dick, It looks great.
Dick Coers
rpm range of 375 to 2700
I have 3 steadies. One ring steady with a sizing cutter, and 2 sizes of four jaw steadies.
