Glasser gouge replacement
John Kaner
Does anyone know of a replacement gouge?
I appreciate any help.
John Kaner
Re: Glasser gouge replacement
Don Evans
Go to "MARKETPLACE" just above messageboards and find Thompson Tools.
He sells them without handles. I believe he took over the line of tools Glasser was making but they are improved now with cryo.
Don
Re: Glasser 3/8" gouge replacement
david
When my Glasser 3/8" gouge (with the red ribbed handle) got too short to work in the Oneway sharpening setup, I got a 3/8" unhanded gouge V-profile from Doug Thompson, who had mentioned that the Glasser gouge handle can be re-purposed. Took the handle to a friend with an Oxy-Acetelyne torch. With enough heat the the old gouge can be removed and you can use CA glue to secure Doug's new gouge into the old handle.
Did you look at Glaser Hitech?
Dick Coers
They are still made, but I personally prefer Thompson.
Thank you very much Don
Thank you very much David
John Kaner
That is better than the West Coast price...
Great information!
Thank yoyu very much Dick
John Kaner
Going with Doug Thompson.
Re: Thank you very much David
Dale Miner
I have pulled a couple of the Glaser tools from the red handles.
The Glaser gouges are held in the handles with epoxy. A good propane/bernzomatic type torch can heat the handle enough (350-400°f) to soften the epoxy. The handles themselves are made from a tempered grade of aircraft aluminum. Overheating the handle can soften the handle by removing the temper. A line from a black shapie will 'go away' at about 400°f.
Clamp the tool horizontally in a vise with the handle a couple inches away from the vise jaws. Have a good pair of channel lock type pliers and a heavy rag at the ready. Heat the handle and the tool with most of the heat applied to the handle. Periodically using the pliers and rag padding, try to twist the handle breaking the epoxy bond. When the handle is hot enough, the epoxy will soften and the handle can be pulled off the tool.
Epoxy is much preferred over CA for installing a new tool into the handle.
Don Evans
The 2 Glaser handles I have, the RED ones have 2 set screws in them holding the tool in. Never had one that was epoxied.
It seems to me the best way to heat anything like this to soften the glue would be to use the vise 4" one big enough to act as a heat sink. to take heat away from what you don't want it to harm, in this case the aluminum handle.
I would, especially with an oxy/acet set up do it this way:
Place the handle in the vise with the top of the handle even with the top of the vise jaws.
Then heat the tool shaft, never the handle. As heat travels down the tool shaft into the handle it contacts the glue next, the heat would have to travel through the glue to get to the handle where the vise metal would dissipate it quickly.
This would be less likely to harm the handles strength.
Seems the right way to go on paper but sometimes that doesn't always work out, only trying it would tell.
Personally I would do that first before putting heat directly on the handle as the heat then has to travel all the way through the aluminum before getting to the glue. Make sense to me but I don't know about the propane type torches but if that is all you have I would think the "yellow" tanks would be necessary NOT the blue propane.
Don
Dale Miner
Don,
The common propane type torch has plenty of btu's for the task, and the lower flame temperature reduces the likelyhood of overheating.
As with most things though, there is more than one way to skin the cat.
Re: Thank you very much Dale
John Kaner
This is good information.
Re: Thank you very much Don
John Kaner
This also makes sense. I remember learning to solder, if it was dull, wasn't done correctly.
John Kaner
Called Doug. I have the black handled 1/2" and my friend/mentor a red 1/2" Glasser gouge. I wanted to verify sizes. I still thought my handle was red and 3/8"... LOL
Blame it on the florescent lights... or age... LOL
Doug is a great guy to talk with and explained the whole procedure. At this point, I still needed to verify color handles and sizes. Doug was very helpful. Another phone call tomorrow and then send a money order on Monday.
I have about 3 3/4" left on flute and Mike has about 2"!
Wish there was a use for the soon to be fluteless steel...
Re grind it
Stuart Johnson
Turn it around and grind it into a 3 point tool.
How much do you grind?
Dick Coers
3 3/4" seems like a lot of flute left to me. How long do you think it would last for you?
Re: How much do you grind?
John Kaner
Dick, bought it used 2 years ago. had 4" flute. Wish I could have afforded a new one... I've been using Bengamin's Best from Penn State...
You're correct, I should have many more years of use...
Bill Blasic
That is one of the great things about JoHannes Michelsen's Vector Grinding Fixture, you can sharpen right up to the end of the flute. This works well for Doug Thompsons tools as they are heat treated the whole length of the flute. You have to be careful as some tools are not the same hardness the full length of the flute and as you get closer to the end of the flute you have different results as far as sharpness and how long the edge lasts.
