Hackberry question
Keith Newton
It has been a long time since I've used any Hackberry, and there is some on the curb a few blocks away with a lot of black in the heart. Does the black fade as it dries out?
Hackberry question
Keith Newton
Re: Hackberry question
Stuart Johnson
No it stays nice and black.
agree
Agree
Here's a little piece I made a while back. Ebony lid, mastodon finial. Gotta be five years or more. No degrade at all on the color.
Re: Agree
Keith Newton
Well, That looks cool enough to get my interest. However, I didn't see spalt lines, it appeared that the whole heart region was black on the ends with the broad white sapwood band around it.
It was raining here all day, so I didn't want to get out to load it in the rain. The rain has turned to sleet, but is suppose to turn to snow soon, so I'm not too excited about getting out until the roads are cleared.
Being related to the elms, which turn pretty brown on the ends shortly after being cut into lengths while green, I was kinda thinking that might be what happens with this.
Re: Agree
Stuart Johnson
Hackberry rots pretty fast so you will want to get under cover and sealed as soon as you can. I've found the best way is on end in the garage. If the piece Ellis is showing is some of the wood I sent a few years back, it was fresh cut and stored that way for a couple years. Neither end was sealed. There is another piece from the same tree in my gallery.
Holds the color very well
Dick Coers
This time of year, it stores very well. Spring and summer, you can get some gray in the sapwood which really ruins the lovely cream color. Dark heart holds pretty well, but fades just a little with longer age. Don't we all!
Re: Holds the color very well
Phillip Medghalchi
Dick, is that a good email for you to send you and email in front of your name? I's like to ask you about the crotch wood, if you do not mind?
Phillip Medghalchi
Keith, I got a piece of it last spring and it ws so wet that I had trouble lifting it. then I set it down on its end and now it's split at 2/3 of the length and end is gray. I have to cut it down, but what I was going to say that it was really balck in he pith area and it had an unusual smell to it. For both our sake I am going to cut one end and see what reveals, and report.
On the other hands, I ahe eard it spalts very beautifully ad that's what you see in E
Ellis's box.
Rich Egan
Keith: We have lots of hackberry where I live. I have found it to be of medium weight, kind of open grained, and fairly well behaved as far as drying and cracking are concerned. Ours in Wisconsin can have a greenish/yellowish color, but that may be different where you live. I have a natural edge bowl in the member gallery which is hackberry. Any free wood is worth a try.
George Taylor
I have had good luck with Hackberry; it definitely needs to be twice turned. I have finished with lacquer and danish oil ... neither had adverse affects on the pieces.
yes, that's my email
RCH
It tends to spalt fairly quickly on its own, at least in KY (and not in the winter), and go punky fairly quickly after that, even when sealed. The spalting can be really nice. I've always turned it to finish whenever I've worked with it.
I went by and picked up 4 pieces.
Keith Newton
I'm roughing one out now, and as I suspected, it is darkening from the ends, while the heart is still light brown. I'm not sure this is actually spalting, or just what it does as it oxidizes, but from the ends, it is black as ebony.
I almost always turn green to finish. It is about as full of water as wood can get, plus it had about 2" of wet snow standing on it. And if that wasn't bad enough, I had to roll it across a gutter, while the outside was snowballing. I was wishing I hadn't eaten so much of that venison gumbo that I made for my late lunch.
