Shocked by my lathe.
Ray Carson - Lawrenceville, NJ
Has anyone ever been shocked while buffing a turning? My son and I were working on his duck call this weekend and while I was buffing it out I would intermittently shut off the lathe to check the progress. I would buff and upon touching the on /off switch, I got sapped. Really bad a couple of times.
I can only assume that it's very dry in my house and the buffing action created the static electricity.
Besides grounding myself "out" every so often, can I prevent this by other means?
btw
(Duck call picks coming soon)
Re: Shocked by my lathe.
Ralph Lindberg
I would NOT assume it's just static. I would carefully check and ensure that it is "just" static.
Honestly, it could be your life.
Bill Howatt
The dry air, if it is, would be my guess and the easy solution may be a portable humidifier near the lathe. If the lathe isn't in a huge room, you may be able to achieve the effect with a pan of real hot water or an electric kettle boiling away.
I don't know about trying grounding techniques since you can't ground an insulator as the dust collector people say. Also, having "wires" near rotating objects doesn't seem prudent.
Bill
Doc Green
Ray, you got zapped when you touched the big red button, right?
The big red button is made of an insulating material, plastic of some sort, that will not conduct at low voltages like 120 or even 240V. It would probably take thousands of volts to produce enough conduction for you to feel, and this can come only from static electricity.
I just realized that I made the assumption that your lathe has a "big red button," but the same holds true for other plastic switches on other lathes. It is not true for a toggle switch with a metal toggle like is on a Jet mini.
I don't know how you could check the frame of the lathe for a lack of ground unless you have a voltmeter. Do you have a voltmeter?
Static discharges can be painful. That's why I never wash clothes in the winter. Because you have to dry them, and I always get shocked taking them out of the dryer.
Dick Hines
Dick Hines
A dry cold day and static charge will jump a inch or two. I have had days where I had to rest my leg on the lathe leg to keep from getting zapped.
Buffing in cold dry weather will keep you from dozing off.
Steven Antonucci
Frequently
steven antonucci
usually followed by bad words...
As an aside, when we were kids, we had old cast iron radiators in the house and my grandmother used to set the heat on infinity. Couple that with wall to wall carpeting, and my brothers and I would sneak up on each other from behind and touch an earlobe or a cheek. Did it hurt the shocker too? Of course, it did... but nowhere near as much as being shocked on the earlobe.
Things escalated when I discovered holding a metal dumb bell bar largely disapated the shocker's pain and magnified the shockee's pain...
Everything (except the lack of mosquitoes) about winter stinks...
Steve
Re: Frequently
Bill Howatt
When the house is dry and the sparks are frequent, I take a coin out of my pocket and hold it tightly and let it spark to the faceplate screw or other grounded object (probably best not to use your electronic equipment though) before I touch anything - assuming I remember.
Bill
At my old shop in a damp basement I had a bad ground somewhere and would get a shock from my lathe on rare occasions. This is a totally different shock than I get from the static in my house where I have carpet and dry heat. The shock from the bad ground was a sort of tingling. The shock from my carpet is a sharp pop. It's so bad my dog ducks each time I reach to pet her. I added a humidifier that I run all the time. It reduces the shock but didn't get rid of it.
Pop vs. tingle
I checked everything out on my lathe, outlets, etc. All fine.
John Lucas kind of hit the nail on the head. I get more of a pop than tingle. I guess "shock" was a bad description. Touching the on/off switch had no effect. Touching any metal part on the lathe results in a short pop.
As a test, I took a old turning and tried to get different results. The harder I press the more I get shocked, but it didn't "phase me." Every so often I would ground myself and the "pop" was less noticeable. So I think it's static electricity. I'm just surprised because, I've never had this happen before.
I’m ex-static it's not something serious. :)
Re: Pop vs. tingle
If it's a ground problem it will usually continue to shock you until you let go. The static shock is very short lived.
Be careful
Harvey Meyer in Atlanta
Recently I went to install a replacement inverter on a buddy's Powermatic. After I wired everything up and went to turn on the lathe, I got a shock when touching the metal body of the lathe. Not static electricity and I could feel the 60 cycles. I've worked with electricity a lot in my life. I know a real shock vs. static electricity and I can also tell the difference between AC and DC. I set out to find out what was wrong. Of course I thought it was something I did, but the inverter wiring was fine. I tested his power connection and it was properly grounded and the ground was present at the inverter. He had all kinds of stuff bolted to the lathe - lights, vacuum pump, remote foot switch, fan, power strips, etc. I found that something was leaking a small amount of voltage to the lathe. I unplugged everything and the shock was gone. The power strip that he had all of the miscellaneous junk connected to had no ground. It was plugged into a grounded outlet, but there was no ground present on the middle lug of the outlets in that power strip. I ripped out the power strip and asked him for another one. Plugged his stuff back in and no more shocks. BE CAREFUL!!!! If it tingles, it's not static electricity.
Humidifier
You're correct again John. Fix the humidifier on my furnace, ran it for 24 hours, went back to the lathe for a buff, no pop. Static electricity.
Not clear to me
Bill Howatt
From the post my understanding is that you got a shock from the grounded lathe and the problem was some device plugged into an ungrounded faulty power-bar.
The only way you can get a shock from the grounded lathe is if you are touching the "leaky" device and the grounded lathe or some other grounded object including a damp cement floor. If the lathe body is at ground potential then there is no way you can get a tingle from it by touching another grounded object. If you are getting a shock from the lathe because the leaky device is attached to it then I'd say the lathe is not being grounded properlyl.
I have a very, very old refrigerator with a 2-wire plug that would give a tingle if you touched it and a grounded object such as a stove. Putting a ground wire on the fridge to drain the leakage to ground solved the problem and it has been running this way for 40 years.
Normally leakage voltages that tingle are high-impedance sources leaking through some insulator. If you put an analog voltmeter on them they will show a high reading on a high-voltage scale say, 50-70 volts very roughly, and then as you drop the voltmeter scale the voltage will drop with it due to the increased loading of the voltmeter. This doesn't work on most digital-voltmeters because the exhibit a very high impedance regardless of the range.
Bill
Re: Not clear to me
Bill - I agree with you. It defied logic. All I can say is when I got rid of the power strip which had metallic contact with the lathe, the shocks went away. I was standing on a cement (dry) floor on an unusually warm Atlanta winter day. The lathe owner had a rubber mat in front of the lathe, but I was off the mat. I was wearing sneakers. He said he never got shocked, but always stood on the mat. I didn't verify that the lathe body was at ground potential. I did verify that ground was present at the inverter and also on the ground terminal heading to the motor.
In addition, the new inverter I installed was mounted to a wooden board, not directly to the back of the headstock. Therefore, the grounded inverter will not ground the lathe body, but theoretically, the grounded motor will. I only had my digital Fluke meter with me and I knew the high impedance wasn't going to help determine the source. I inspected everything that was mounted to the lathe, checked all the wiring, etc. and could find nothing other than the groundless power strip. After replacing it and replugging in all of his devices, all was well again.
I'm too far away from him to recheck anything, but he's been happily turning. I suspect that power strip, was the tingler. I'm agreeing with you, it doesn't make sense, but that's what it was.
