Actually defending carbide tools...
steven antonucci
I read the carbide thread with the usual amusement we get when discussing it, but I actually found a use case that I think I prefer carbide over tradition WITH A REASON THAT IS SCIENTIFICALLY SUPPORTED!
Carbide is hard. Wood is not (comparatively). What if you weren't turning wood, but something substantially harder?
I've been casting pewter accents in some recent work. Pewter is substantially harder than wood, but it still cuts easily with traditional tools...so that isn't it.
If you've ever put brass or copper ferrules on a tool handle, both are substantially harder than pewter...but you can cut them with traditional tools. You will need to sharpen when you are finished, but they both will work.
So...what is it that carbide is the right answer?
Stone. In my case, it is alabaster, which is pretty soft as stone goes, and could be cut with traditional tools if you wanted to sharpen every 2 minutes...but carbide just works better here. My hollow form (Still in progress) was 99% turned with a Hunter cutter (inside and out), except for the undercutting...because the swan neck tool is on loan to a friend. Perceptually, the cutter feels no different than when I started...
I'll post a picture when it is done later today.
Steve
