simple photo technique from florida demo
I was asked to do a short demo on shooting your work at the florida demo this last week. this is about as simple as it gets and as you can see it's pretty effective. I used white paper that I got from Office Max. I think it's used for packing. roughly 20 wide and a very long roll. taped it to the wall and rolled it out into a gentle sweep and then clamped it to the table.
I used a 12" reflector with a white cloth diffuser. It has 3 45watt CFL bulbs rated at 5500K. I added a white reflector on the left side to bounce light back into the shadows. The additional highlight on the left is from the ceiling light we couldn't turn off.
I move the light up and to the front slightly so it lit the top and right side of the piece leaving a shadow on the left to give it shape.
I exposed the image about 1 stop over exposed since I was using a white background that filled a lot of area. I only did a mild 6 points magenta color correction because my lights are very slightly green.
These were both quite glossy. Not a glass type of deep gloss but a pretty decent glossy finish applied by a good turner.
This could have been done better but I shot 2 vessels in the space of about 15 minutes and that included talking about how to change things and why this works as well as showing them some exposure problems. The glare isn't too bad. using a small light created a smaller glare problem. I could have pulled the diffuser off used a polarizing sheet and a polarizer on the camera and gotten rid of 90 percent of the glare. It usually leaves a very small blue dot which is easily retouched in photo shop if you don't want any glare. Or you can not polarize it all the way and it just reduces the size and intensity of the glare.
