WoodFast Lathes
WoodFast Lathes
WoodFast Lathes
Ray - Middletown, IN
Anyone know the spindle specs on the Woodfast, and any other info. A friend sent a pic but the model doesn't show and I don't think he can get another soon. Appears to be about a 20" swing and 42" or so long. TIA Ray
Re: WoodFast Lathes
Re: WoodFast Lathes
Thanks Sergio, I just assumed it was no longer in production. The one in my pic is blue and the phase converter is mounted on the wall. I'd bet the basic info is the same.
Ray
Re: WoodFast Lathes
Re: WoodFast Lathes
Roger Chandler
Is it just me, or does anyone else see design similarities with the Vicmarc and the Woodfast? I wonder there is a common manufacturer to both brands like there is with the Powermatics, Jets and others made by the Burt Group?
Re: WoodFast Lathes
Re: WoodFast Lathes
John Jordan
Nope, they are entirely separate, but they do have in common simplicity and a similar look. The REAL Woodfast was a dandy lathe, same with the vicmarc. The Vicmarc has a lot more cast iron in it.
John
Re: WoodFast Lathes
Re: WoodFast Lathes
Geoff Whaling
Roger,
Woodfast manufacturing predates Vicmarc by at least four decades. I'm not sure when they started but I have seen ads for used or S/H Woodfast machines from the early 1950's. Woodfast Machinery was established in South Australia and manufactured a range of wood machinery. Most of us who went through school or technical colleges in the 1950's through to the early 1990's and even later would have used almost exclusively Woodfast wood machinery as they were an education standard in most states. Like many Aust manufacturers Woodfast struggled against imports and eventually succumbed selling to I believe O/S interests. The lathes are no longer manufactured in Aust but retain their design heritage.
Vicmarc started manufacturing in 1984 in Clontarf Queensland. Always have been a very good lathe in comparison to their contemporaries. Vicmarc still do much of their manufacturing, finish milling & assembly here in QLD but have to out source castings O/S as it is no longer viable to manufacture/cast them here.
No idea why Vicmarc have any similarity to Woodfast, maybe that Woodfast was the dominant machine prior to the 1980's and heavily influenced design.
Australia & NZ also manufactured other very good lathes post war (WWII), Durden, Tough, Tanner (NZ) and much latter the Stubby come to mind.
Re: WoodFast Lathes
Re: WoodFast Lathes
Geoff Whaling
John, I believe the current M910 Woodfast/Rikon lathe is a very good lathe for most wood turners. It still retains the original Woodfast M908/M910 design heritage.
A REAL Aussie mad Wood fast looks something like this - green & Aussie made M908 1993 vintage - beautiful castings - solid & very well made. Now has M910 EVS. (ps I'm 6'2" to give some scale)
Re: WoodFast Lathes
Re: WoodFast Lathes
Roger Chandler
Interesting information Goeff......I appreciate the timeline on development of them both.........they do look similar in some of their castings and your guess is a good one that is plausable!
Re: WoodFast Lathes
Thanks for the help.
Here is a pic of what I am supposed to evaluate.
Not much to go on. Ray
Re: WoodFast Lathes
Specs
Geoff Whaling
Ray,
Have your friend look at the RH end of the ways - it will have a month/year stamped into the ways. Also look at the motor ID plate should have a year of manufacture on it as well if he can see it, though yours looks like it has a retro fitted EVS - box on the wall. The RH end sticker (obscured) on the front of the bed ways will have either M908 or M910 on it.
Looks like a standard M910 long bed to me about early to mid 1990's. Could be a M908 but doesn't look like it given the relative size of the speed plate to the head stock.
Here they had mostly 1" x 10 spindles but may have had 1 1/4" in the USA - though I do not know for sure. Specs are much the same as the Woodfast/Rikon M910 but older models do not have the quatro bearings, just one each side.
Not sure what you want to turn but I think you will be pleasantly surprised at the quality & strength - very much like a VL200 Vicmarc in capacity etc just the castings are a little less robust - not much mind you.
Re: WoodFast Lathes
My 20+ yr. old Woodfast short bed....
JamieDonaldson
.... is still a favorite when I don't need the brute power of my Stubby(Studly!) I haven't turned on a newer China made Woodfast, but have been told that they are not the quality of the originals, although the castings are very similar.
Re: WoodFast Lathes
Re: Specs
Geoff Whaling
Oops I think I typed that ar$e about - should read - It looks like an M908 not an M910
