Re: Lathe Upgrade
Dale Bonertz
Good luck in your search. Geoff mentioned that vicmarcs are un-killable. I have to agree. A friend of mine has had a VL300 for 25 years and has never turned it off (I am referring to the VFD). He has never replaced anything (bearings, VFD drive, motor, belts or anything). That is after he has rough turned over 35,000 plus (that is correct) bowl blanks. That speaks volumes to me.
If you are a hobby turner the 3520B will work for most people but you always hear, on forums, of this going bad or that going bad and etc. I am not a fan of sliding head stocks. When you have the most important component of a lathe and it is movable you are introducing potential problems (vibration, twisting the bed, not holding down tight, spindle not lining up with the tail center and etc.). It is easy to understand that having the head stock fixed over a solid foundation (the legs) is a superior design. If this is the last lathe you intend to purchase I would sincerely consider, out of the three, the VL300 or the Oneway. If you have a lot of accessories then look closely because the Oneway has some different morse tapers and I think different threading on the spindle Been awhile since I viewed all the specs on that lathe. Al can jump in to note the differences from most lathes. It may cost you quite a bit to adapt your accessories to that lathe. Most lathes and standard accessories have a 1 1/4" x 8 thread on the spindle and #2 morse taper. Again, good luck with your search and try to turn on all of the lathes you are considering.
