Yarn bowl question
Yarn bowl question
Yarn bowl question
Sergio
Hello, I intend to make a couple of yarn bowls. I never made them and would like to know which is your experience on the size and how to make the cut where the thread goes through. Also, is there a reason why a hole is not enough?
Re: Yarn bowl question
OK I've only made one but here are my thoughts. Mine was 9" and about 5" deep. Too small Probably 12" and 6" deep is better. I cut the slot with an air saw but it wasn't a good choice. an OK choice but I'm sure there is a better way. As far as the hole goes, the yarn needs to stay in the hole not in the slot. So design the slot accordingly. In other words when the yarn falls down and doesn't have pressure pulling it up make sure it doesn't fall back in the slot to be pulled out the first time you pull on the yarn. Mine sort of fits that but not every time.
Sergio
Thank you, I undestand the concept and that is why I'm wondering why I've never seen a simple hole but only comma shaped cuts. Yours, if I recall well was heart shaped. Am I right?
I have only a jig saw, whould it work?
Rum
The idea of the slot is so you can remove the yarn from the bowl with the project attached. Sometimes that's nice to be able to do for various reasons (I don't know them all - but the knitter says...). With larger bowls or smaller projects they'll stuff the project inside and you don't really want any dangling bits in that case either so you can just flip the yarn inside.
Here's a pic of a couple. The calabash shape seemed to be fairly popular, the more ?I dunno what that shape is but I wish I'd done something different? one not as much (you'll also notice that the slot wandered a bit from the grain line on that one.. :\ ).
I just used a coping saw to cut the slots. Marked the line I wanted, drilled the end point and then cut along the line. Worked pretty well but had to clean up the edges with some rifflers a smidge before sanding. A jig saw would be hard to control and be bad for tear out in this use case (imho) but might be possible.
The size depends on what they're going to use it for. The calabash shaped one is only 8" wide by 5" tall, but that's plenty big for a pair of socks, a light shawl, a scarf or similar. If the knitter was going to do sweaters, or something like that it wouldn't be. The tradeoff with a larger bowl is that it's heavier/bulkier so it's more annoying to carry and also the more loose the yarn is the more it'll tangle up. Most of the ones I see in the shops around here when I'm in there with the boss are ceramic and are often a sort of straight sided jobbie which isn't to big, maybe 4" across (just wide enough for a ball of yarn) and 8" deep.
The next one (aaannny day now) will have a lid of some sort and a handle I do believe...
Ralph Lindberg
My wife is both a knitter and a turner...
Her favorite yarn bowl is very close to the one that Rum has on the left, that is something like a calabash shape.
She never cuts a slot in it, as she found she doesn't like pulling yarn through a hole.
The problem with cutting the slot is doing so smoothly.
She says sand, sand some more, then sand again.
She has made one for a friend that wanted a lid with a hole in the lid. This is to keep her cats out of it.
On related issues, she makes a lot of Nostipinne's or yarn-ball winders.
She is currently working on making a Yarn-Annie, or Yarn-ball "spinner"
barry rockwell
Barry Rockwell
Sergio, I made quite a few last fall for a Yarn & Knitting shop owner at her request. They were all about 6-7" diameter and about 3-4" deep, Besides the comma slot she wanted a second hole in them. They all sold immediately for about $110 each. I first drilled the hole, then cut the slot using a fine toothed saber saw. Then you start sanding. Sanding the hole and slot took about twice as long as the whole rest of the bowl. They were great sellers, but I got tired of making them.
Sergio
Thank you all.
Darryl
Sergio, there is another approach to the yarn business. It is a notspinne (sp) or some such. Scandinavian I believe. It allows the user to unwind the skein and rewind it into a ball with the end coming out of the center. No bowl is needed. I made the bowl thingy for my Granddaughter and then she found this other thing. It is just a tapered spindle with some grooves. She uses it in preference to the bowl. Probably because the bowl is too small and heavy to carry around.
Brad Vietje
Nice -- I Like the Feet, Too !
Brad Vietje
Any Photos ?
Brad Vietje
Ralph, I'm sure we'd all like to see the bowls as well as the other items if photos are an option.
I'd also like information on thickness and weight -- I imagine a heavy-ish bowl would help (?)
Safe spinning,
Brad Vietje
Newbury, VT
emm... not really
Ralph Lindberg
A nostepenne is more for making a center pull yarn ball, not holding the ball while knitting.
A yarn bowl or "Annie" (something like a vertical paper towel dispenser) are really for holding the ball while knitting
Re: Any Photos ?
Ralph Lindberg
She's just back from surgery and my time is limited right now, I will try later
Re: emm... not really
Rum
The one spinning teacher loml had that heavily used nostepinne's (I made them about 30 for the class to share) definitely knitted using center pull off of the nostepinne. Said it worked especially well for lace weight since it keeps the ball from collapsing as you could just slide it back up the taper a smidge as you went. I'm assuming that eventually it would still be a problem since the ball is much larger than the taper.
The spinners really like then for doing small sample batches onto as well.
From a turning perspective the nostepinne is a fantastic skew practice project. Great way to come home from work and knock out a half dozen to relax :D
I have a slight preference for doing spinning wheel hooks because there are "no" rules (mostly no rules) on how they're shaped so you can use smaller scraps and be more creative as well. I've seen seen really fancy nostepinne's though - you can get pretty detailed on the handles, mine were more utilitarian but once I went back and forth with loml 5 or 6 times I got the functional end about how she liked it :D
john Veerkamp
I make several different sizes, from4" dis to 7". Knitters who use sock weight yarn often like the smaller size while those who knit from full size skeins like the larger sizes. Any slot you can imagine will work as long as there is an upward section to stabilize the yarn when pulled. For custom bowls, you can sometimes personalize them using the persons initial as the slot shape. Hole only ones don't sell as well. Lidded ones are nice for folks who have pets that like to get in the yarn. They also help to keep things clean in dusty environments or in long pauses in the project. Thinner walls look nice but the bottom needs to be heavier to be stable while knitting or crocheting.
BTW really small boxes with a tight fitting lid with a hole in the center are nice for tatters. Boxes about 2"X2". The more interesting the wood the more desirable.
Re: Any Photos ? Noste's
Rum
Like I said, mine aren't fancy... you can make the handles as spiffy as you want but this gives an idea of how they're made.
You can make the shaft thicker or thinner, this is about as thick as I'd go, and I've made some down to about 1/2 that thickness which worked nicely for thinner yarn.
The other key elements are the even taper to the shaft and the appropriately sized grooved at the tip and by the handle (they're used differently for different winding techniques and now you know as much as I do about that part).
Alone
In use:
