drill rod to curved tool rest
HeatherAinAK
Hello, I was wondering if there is a way to apply drill rod to a curved tool rest. I have a powermatic 4224 that came with the left and right tool rests. I really love my Robust straight tool rests with the drill rod type top. Is there a way to get a piece of drill rod or other steel bent to conform to the curved tool rest profile? Or is there a non-hardened steel that I could then harden after bending. I have some friends that could help me out with the metal working part but thought I would check here if this is something anyone has experience with.
Thanks,
Heather
Re: drill rod to curved tool rest
robo hippy
The drill rod must be bent first, then hardened, then applied. The first one I got was epoxied on with JB weld or some thing like that.
robo hippy
HeatherAinAK
Thanks, I actually got the idea after watching your tool rest video! Trying to save a few pennies.
Heather
Heather Drill rod usually comes annealed meaning it is not hardened. You should bend it while it's in this state. It's pretty hard and tough as it is. At home it would be difficult to harden a rod that long. I did an article about 12 years ago on tool making for American Woodturner and in that article I showed how to anneal large files by heating them in a charcoal grill with the charcoal to get them red hot. Then you let it cool overnight and the files are annealed. You might be able to cover the rod with coals and let them burn to the point of being red hot, then pull the rod out and quench it in water (if you bought water hardening rod which is what I would suggest). This should harden the rod but it will be too hard Let it cool and then put it in the oven at 425 degrees for about an hour and it should be tempered enough to be hard but not brittle. Then you could epoxy it to the tool rest Ideally I would file the top of the tool rest flat and then maybe scratch it with the file to give it more tooth for the epoxy to hold.
