a comment on photography - and check out my newest
darrin hill
so i became a professional photographer back in 1992.. in 1997 i bought a 5000 square foot studio.. this was my camera room.. notice in the back the two soft boxes... i had a light source that was 16x8 feet... bigger the light source, the softer the shadows...
now i have this.. one car garage that has an empty 200 gallon fish tank... 2 11x14 studio cameras on stands, 2.5 million negs, lots of bee stuff.. and the background...
problem was that i have no space.. the background alone was an old 12'x25' muslin..(feet)... and i was using bigger stuff.. the background was dark... and it absorbed light.. it was hard to get the light right on the object AND the background... and i was gettting weird reflections.. not to mention wrinkles...
notice the highlights have separations.. and everything that was light colored (ceiling, me, whatever) showed up..
so inspired by keith tompkins i bought the background he uses... 32x46 inches..
i now use this...
bed sheets are double layered... so flash hits one, gets bigger, and then hits another, and gets bigger.. bigger the light source, the softer your shadows... and yes.. im using whitelighting 1600s (studio lights) and professional flashes... and the sheets are held up with things called combitubes.. made by foba.. its a tinkertoy set for photographers... you can build anything.. stands, holders, tables, supports, etc..
the cardboard with the hole in it... one flash on the left is aimed not at the vase, but halfway between the vase and the camera... it spills light past the background, hits the cardboard, and reflects back to the vase and fills in the front.. otherwise only my sides would be lit and the front would go dark...
and i get this.... to avoid reflections from the white part of the background, (ie the forground of the background) i took that vase that i spent days getting all lacquered up and shiny, and i stripped it all down to wood with 400 grit and then 1200 grit... now its no longer reflective... but it is dull... and the color does not quite pop out after sanding,... when it had a fresh coat of tung oil, it was a little more vibrant... and no.. its not a photoshop issue.... its the wood..
so whatcha think? its called 'anasazi'... and about basketball size.. MUCH CLEANER, background wise..
original background setup for comparison..
Re: a comment on photography - and check out my newest
darrin hill
so the new background takes up a lot less space... easier for me to use..
and kudos to john lucas for telling me to photograph before applying shiny finish..
was racking my brain on that one..
You can apply finish I just knock down the gloss with 4/0 steel wool. You normally want the color the finish gives it to come through.
I was the first one to use white lightening flash units I was selling cameras at McGinnis camera Paul buff brought a light that looked like a paint bucket and try this out and let me know what you think. It was about 160 watt seconds and had 3 power setting and was very inexpensive. It was ugly but we sold quite a few
Ron Bauer
Now you guys are scaring me about photography! I want to (have to) take photos of my work so I can get them on a website to reach a larger audience. I don't know nuttin' bout pikshurs but know I need to do things better. Many of you pro's have given great advice in the past and I will try to follow it as best as I can. I guess I just need to take my best shot at it and improve with time. Ron.
Photography?  I think your turnings are amazing !!
Ray Carson - Lawrenceville, NJ
Being your own critic can be a blessing or a nightmare. I'm a shutterbug too, I don't see any issues with the photos. :)
Nice shots Darin
Keith Newton
I like the way the seamless background has a gradual transition. But the two layers of sheets, while obviously effective with your flash, seems like it would absorb a lot of light, for anyone who doesn't have as powerful a light source.
My favorite diffuser, is even cheaper. Just think about what your could do with white tall kitchen waste bags. They are much more translucent. You could cut one open to tape onto your close frame, then hang another pre-diffuser closer in front of your light source.
I suggest that your lighting.....
JamieDonaldson
... is too evenly balanced from both sides, and a slight mismatch would enhance the appearance of depth. Shadows are not evil, and provide the 3D effect in an image, so total elimination of shadows is not desirable in many cases.
Re: I suggest that your lighting.....
I agree with Jamie. Shadows help show texture and shape on turnings. Really even lighting makes the piece look flat. You have to play around and find what lighting creates the right kind of shadows.
Darrin hill
Been stuck in a hotel room since Friday... Holiday weekend... Visiting inlaws in San antonio.
I tired oooo steel wool and it just didn't know the gloss of the lacquer down enough., so I did the 400 and 1200 grit... Will try again next week.
Shadows and highlights I can deal with.. Wasn't concered with this..
What I was interested in was how the background was much cleaner and simpler... If I wanted to submit to a gallery, this is how I would go.
My only problem with the background is that the white part should be longer so that I could do taller pieces and have the gradation higher... And jsut adding a background and taping it to the bottom would not work cause then u would have to color match the backgrounds white.
What I am concerned with is the blacks of the background looks a bit blue... And combined with the dull of the hollow form, it just makes it all look under exposed...
So do u see the top of the background as blue or black?
