Re: DVD
Bill Howatt
Examine the bottom of the disc carefully looking for anything that looks like surface dirt, fingerprints, etc so you can set a baseline for cleaning and know what you are dealing with.
Remove all rings. Wash the disk in warm, water with a bit of dish detergent. Dry it with a clean paper towel. All washing and drying motions should be from the center out to the edge so if you put in a scratch it will run across the tracks not parallel to a track. It is unlikely you will scratch it but if it should happen this does way less damage than one running with a track. CDs and DVDs all have error correcting codes built in and they can handle errors up to certain number of bit errors which is why you want to make small error zones if you make any.
Compare the disk with your first inspection. Re-do if any still dirt still exists. Now try it.
If you have bad scratches, especially non-radial ones, you can do the buffing and there is a method of using a green marking pen that supposedly worked on CDs anyway, the theory is that it cuts down bad reflections back to the sensor. If you Google you will find various tricks.
Bill
