I am doing my first (of hopefully many more) club demonstration Thursday night. I have been playing with color-ply recently and thought it would it be fun to demonstrate something a bit out of the box. I have found the material to have some challenges to work with but if properly done the results are quite interesting.
I have made a list and went through it twice. Thought I was ready and then realized I had not packed the wrench for my chucks. That would have been a drag! Any suggestions on things others have forgotten to bring to a demo.
I will also be interesting to turn on another lathe. The club has a Oneway but for the past 5 years I have only turned on a PM 3520. (I do have the spindle adapter to use my chucks.)
I will let you know how it goes.
Here are a couple of photos of some color ply items,
I have only turned on the small Oneway, and being used to the sliding headstock, and using it constantly, I couldn't turn my normal style on the Oneway. You may have to adapt.
Nice pieces. It is so easy to forget things. I try my best to make a list and the. Go through the demo in my head. Even then its easy to leave something. Forgot my chuck key twice but since its a 10 mm Allen it was no problem you can get one of those easily although one time I used a big flat blade scredriver as my key.
Tuesday when packing for my demo on natural edge bowls I realized that my fiancé had packed all the bowls I laid out to take didnt have any idea what box she put them in
Of the AAW symposium one year they told me I would be on a powermatic. They put me on a Oneway. Being the smart cookie that I m I had brought my M33 adaptor anyway. I was feeling pretty smart until half way through the demo I remembered they use a #3 morse taper in the tailstock Fortunately my room assistant was able to borrow one from Mike Hare the vendors had packed up before I did so I called him up and purchased it from him. It fits my metal lathe
One of the fellows in our club uses that material to make salt and pepper shakers. He did a demo for the club and turned two nice pieces. He also had several ones he had made previously to show to the club. All in all, a good demo.
I started out bringing too much stuff, and trying to show too many things. Time passes fast, and if you can cover 5 things really well, it is better than trying to cover 10 things in the time available. It always helps to go slow, stop often, and even allow people to come up close to look & feel, though this depends on what sort of close-up camera/video setup is (or isn't!) available. I like to make sure the beginners in the room can completely follow what's going on (and they often don't see the same details a more experienced turner sees), so I try to pitch things at or close to their level.
Demonstrating on a different lathe has certain challenges, so if you get a chance to play with the OneWay ahead of time, it will probably help you feel more comfortable.
Everyone has their own demo horror stories, but mine is about storing your tools. In Albany, about 10 years ago, I stayed over the night before, and brought my tools into the demo room to keep them warm (it was a January event, and about 5 degrees F outside), and the forced hot air heat dried out the tool handles enough that the tools were a little loose, though I had not discovered that yet. Did a "back cut" at the opening of a hollow form that I've done a thousand times at home = catch (Huh ???) Cleaned up the area and tried again = worse catch (WHA ???) Went to my go-to 1/4" bowl gouge -- the tool I use when it absolutely HAS to work -- and BANG! Holy %#$* (smokes, I'm sure it was...) what the hell is going on here ?!?!?!? Turns out, the tools were rotating into the cut because they had loosened up in the handles, and I looked like a real klutz. Lesson -- epoxy those babies in there, and be careful about how your tools are stored before your demo.
I think I can adapt to not sliding the headstock. I expect more difficulty with getting used to not having the tilt away (added to my PM) for my tail stock.
Twice I have had the power go out while I was doing or about to do a demo. Was pretty funny and made the best of things talking about design.
Add 25 to 40 percent time to your tasks to answer questions and explain stuff you just do without thinking about it. It takes time to stop and think just why you do something the way you do it.
As you do more demo's it becomes second nature but the first one can be stessfull.
Have fun and try to not stop talking - dead air gives the chatters time to turn to their friends to chat.
Keith. Last time I came to Atlanta for demos I forgot my suitcase. Had to go out and buy underclothes and tooth brush. Just wore the same shirt and pants for 3 days. Kind of gross but no one knew but me
...talking at home to judge the difference in time required, because it will be quite different than you doing the same project at home while not explaining the process. My most unusual demo experience was flying in to demo and the airline lost my check bag containing all my tools! Had to scrounge and borrow enough tools to work, and using unfamiliar tools in not a good confidence builder!
Jamie, the hotel lost my bags, tools, and demo props (segmented) in Orlando. Good thing I arrived a day early...my stuff was put in a storage closet, and the worker who placed them there had days off...
