OT: Japanese joinery
rd_macgregor
This isn't turning-related, but it does involve wood. The short video with the joinery beam is followed by a longer one (25 min) more broadly about building without hardware.
http://youtu.be/W1pvUlQgYtk
rd_macgregor
Re: OT: Japanese joinery
charlie belden
Japanese temple builders are the high end of Japanese woodworker. Because Japan has frequent earthquakes, temples must be built to accommodate sudden ground movement so some joints must permit a certain amount of "give", while others, such as the splice joint shown in the first video, must rely on complex joinery to keep the joint together.
I found a book, The Art of Japanese Joinery, by Kiyosi Seike, ISBN 0-8348-1516-8, presents 48 beautiful photos of the over 400 joints used by temple builders. When you only have mainly softwoods to work with and often need LONG components for a temple . . .
Here are two "splice" joint examples I did in SketchUp, based on photos in this book.
rd_macgregor
Thanks, Charlie.
My thoughts turned to glues. A tight mechanical joining like these, coupled with a really good glue, would make an unbeatable joint, IMO.
charlie belden
The early Japanese temple builders only had rice or fish glue and iron nails and bolts were rare and expensive. I suspect these glues wouldn't hold up well in damp climates or for 100+ years outside. So they relied heavily on mechanical joinery - and came up with all manner of clever - and strong - joinery.
