working on a video
I'm doing a short video for the AAW on skew cuts and will be discussing why it catches. I was teaching a few guys yesterday and it occured to me that most catches are 3 things. One is trying to use an unsupported edge. (and Lyle did a great article on this several years ago) Typically this would be touching one of the upper wings on a spindle roughing gouge to the wood where the lower U is on the tool rest. Since that wing is unsupported the wood tries to pull it down to that support and pulls it into the wood and you get a catch. The same would be true for the wing of a bowl gouge if you have the flute up. With the skew it's letting the cut get too high on cutting edge so you can't defeat the leverage of the wood coming into it and it pulls the skew into the work. Cutting below the center line on the skew prevents this from happening. If you are cutting into a shoulder or a bead and you have the bowl gouge flute at about 45 degrees the wing that hits that shoulder will be pulled down rapidly since it's unsupported by the tool rest. In that case I simply rotate the flute toward the shoulder so the lower wing of the gouge is now touching the tool rest. It is now supported so it won't catch if it hits that shoulder or bead.
The second is simply coming off the bevel. Usually on the skew it's lifting the handle so only the cutting edge is engaged in the wood. On a bead it's usually because you move the handle faster than the edge can cut around the bead so the bevel looses contact and you get that spiral catch. With a bowl gouge you steer with the handle and it usually means that you didn't guide the bevel along the curve of the wood. Push the handle one way and it stops cutting because the bevel is rubbing but the edge isn't touching. Push it the other way and the bevel isn't rubbing and the edge tries to cut too deep and you get a catch.
If you can imagine scooting a shovel across the ground. If the whole back of the shove is rubbing the ground you don't get a cut. Lift the handle slightly and you start lifting soil. Lift it more (where the back or bevel is not touching) and you dig in too deep and the shovel stops. If the ground was moving toward you it would be just like a catch. The handle of a shove is a very good example of how you guide a bowl gouge so the bevel or back of the shovel controls the shape of the cut.
The last reason is inattention. What happens is you touch the wood with the tool without it being on the tool rest. It of course snaps the tool down real fast and sometimes even breaks the tool rest. I see this a lot. Always pay attention when the tool is anywhere near the wood.
I need to do a video on that. Maybe after this move I can get it done.
Well gotta go to town and sign some more papers and hopefully re-purpose some found boxes.
