Right angle drill
Dick Hines
My right angle died right in the middle of sanding a bowl. It was a cheap one.
I really don't want to go that route again. Any suggestions on a Good drill?
Right angle drill
Dick Hines
Re: Right angle drill
Dennis in Southern Oregon
My Makita right-angle drill has been going strong for 15 years. I just blow the dust out occasionally when I think of it.
Ralph Lindberg
em... I figure cheap is better. I'm on my 2nd $25 one from Harbor Freight (in 10+ years).
Usually what kills sanding drills is the dust, I rather doubt a $100+ drill is going to last a lot longer.
Ron Bauer
Dick, As you might guess there are many differing views on quality vs cost. To answer your question...I have had good luck with a Milwaukee angle drill (actually I think it is 55 degrees). I have used several of the low end drills and they work great until they don't. Certainly they don't last as long. I have just got a HF air drill and a HF air random orbit sander. I really like how a random orbit does away with swirls. If you have air you might want to think about those options. They are both CHEEEP at the Harbor. My TCW. Ron.
Dick Hines
I would go with an air tool but my compressor is not large enough to is not big enough.
You are right about working until they don't. I have had two die in the last month.
George Hurlburt
I have a right angle drill and seems like I get a surprise when I chuck something into it . It turns on when you least expect it. I will quit pluging it in until I'm ready to use it.
Dick Hines
I bet that hot your attention.
Mike Potts
Dick, I'm thinking going to a Ridgid JobMax the next time my cheap sander dies. I have a lot of Ridgid tools in my shop and haven't had any problems with them. Ridgid is the only one offering a Life time guarantee.
keep it safe
Mike
robo hippy
I think that the main thing that kills them is that they are drills, and we use them for grinders, and the bearings are not built for that. I used to blow mine out every time, and got lazy about it. It didn't make any difference. I was looking at the Fordom 1/3 hp motor that they have now. I called and asked them how big of a disc could I run off of it, and they said no more than 3 inch. After visiting with Dave Schweitzer (D Way Tools) and seeing that he uses a 5 inch disc and he says it is so much faster than a 3 inch disc, I started thinking.... Flex shaft on an articulated arm that runs off a mini lathe variable speed lathe or separate motor. That would have the horse power, and would never wear out.....
robo hippy
Barry Rockwell
Dick, I am one who usually would pay a little more for a quality product. I have a Makita DA3010F right angle drill that I bought in 2004 and have been extremely pleased with it , and I have used it a LOT! It's variable speed, reversible, and I like the control of a right angle drill as opposed to an angled drill/sander. I have ONLY used it as a power sander since new, and had to replace the brushes once( about $5). It's a little pricier than others ( currently $190 on Amazon) but it has been bulletproof, and if it needs parts they are always available. That's my 2 cents worth.
I might add that I bought it on the advice of Richard Raffin who told me that he had been through several other brands before finding one that lasted.
Reed I think I would agree with you and I believe I read that in an article somewhere. However I think that would continuous use. Drills are often tested by seeing how many large screws they can put into a board before the battery dies. That has to be tough on a drill. But then again they don't do that hours at a time like a production turner would do. The motor and bearings just aren't up to that task.
I think your idea of a heavy duty flex shaft coupled to a motor would work. One of my friends did exactly that for carving purposes. He adapted a flex shaft he bought Woodworkers supply to a 1/2 hp motor. Tool some jury rigging to make it fit the 5/8" shaft but he would use large carving cutters and sanding discs all day long to hog out wood. His claim to fame was extensive deep carving on thick bowls so he really put it to the test.
Re: Right angle drill rebuild
Stuart Johnson
Terry Daniels (remember him) posted several threads about rebuilding the drills. I don't know if it ever got into the articles but should be available if you do a search.
robo hippy
I guess one way to test it would be to see the wear differences/longevity if I used only 2 inch discs. I almost never use them. I did find a place in Seattle that can make variable speed motors to any specs I want, minimum order 10. I may end up giving that a shot. While the angle drills work, they are not up to production standards. Insert 'Tim the Toolman' protosimian grunts. I don't need a V8, but for sure, some thing more heavy duty.
robo hippy
Re: Flexible shaft for sanding
David Gilbert
I used a couple of cheap right angle drills for sanding and didn't like them for two main reasons. The first is that they were very noisy and the second was that they were very hard on my hands. My hands hurt after sanding for a while so I found a new sanding process.
I bought a flexible shaft from Penn State (they've now discontinued it) and then found a similar version at Garrett Wade that I attach to an old sump pump motor that I hang from the rafters. It runs at 1750 which is too fast but I'm able to turn my lathe down to 25 RPM so it works pretty well. With the 2" discs from Vince the flex shaft lasted a long time. I then upgraded to his 3" pads and the extra torque breaks the windings in the shaft faster than I would like. I've thought about the Foredom but haven't jumped at it yet. Does Foredom have different weight flex shafts?
Cheers,
David
George Balock
Dick,
I consider my sanding drill to be a consumable like sandpaper. I use it till it dies. I've tried the drills over $100 and the cheap ones and they all die , unfortunately at the wrong time. So, I buy the cheapest one I can find. Currently, I'm using a Porter Cable variable speed corded straight drill. It hadles the 5" discs with no problem. I think I paid $60 bucks for it at the local Ace Hardware.
I use a Dewalt $60 drill for 2" and 3" discs. I've been using it for 10 years now but since I don't do a lot of bowls that's probably 1 year for a production turner.
robo hippy
Most of the flex shaft systems seem to be made for 10,000 rpm or so, which is way too fast. I have to investigate more, but there are some out there for industry that should work. I did find with my Sioux/Milwaukee angle drills, that after I started slow speed sanding (no more than 600 rpm) and using lighter pressure, I went from 300 or so bowls to well over 400 before the bearings were shot. If the motor is bogging down at all, it is being damaged. I did buy one of the cheap drills, and it didn't last for a month before the plastic casing around the bearings wore out, not even 50 bowls. I will keep searching and see what I can find, there has to be some thing better. I just can't bring my self to use throw away tools. My dear departed Irish Grandma who lived though the depression would come back and haunt me....
robo hippy
There is one downside to Flex shaft systems. ONe is the shaft needs to be lubed fairly often to work successfully. You can get a Foredom flex shaft machine that has variable speed and will run quite slow. For how long I don't know. I've used with drum sanders at about 1/3 speed for long periods of sanding and carving. The other downside is eventually the shafts break. Not sure a Foredom will run a 3" disc for any length of time.
You may find a Universal motor that could run off of a Router speed controller to slow it down or maybe even find a motor that runs slow and then use a heavy duty flex shaft like the one Woodworkers supply sells.
I switch drill when it gets hot
Aage Rendalen
Dick, as you know, I'm not a production turner, but I turn more than average, I would think. My cheap drills last a long time, possibly because I switch to another one when the first one gets hot. The first grit is the crucial one, so I use from 1-3 drills on it, then finish up with the higher grits at a much faster rate. I usually finish with my random orbit 3" Makita, which is great.
Re: I switch drill when it gets hot
Dick Hines
We'll,after a lot of thought I went to Harbor Freight and got two drills. As hard as I use them I just did not want to spend the cash. I am going to mark the date on them to see how long they last.
Thanks for all the information everyone posted.
Foredom?
Henry (Raleigh, NC)
I picked up a Foredom off Craigslist a few months back, but have not used it. So I can't answer whether there are different flex-shafts available.
I would say that if you noted the difference in torque on the shaft between a 2" and 3" pad on your previous tool, the difference of one of the Foredom carving or cutting bits and a 2" sanding pad would be equally great.
In the absence of any experience or evidence, I doubt that the Foredom tool would stand up to that kind of regular usage.
My completely unvalidated opinion.
Henry
Phillip Medghalchi
Barry, oddly they sell it on E-bay as high as $350, and on Amazon it went up to $206. I believe you at that price you should expect it to last that long.
Alan Hollar
I have Dewalt right angle drills I have been using for sanding for the last 15 years and they all still work.
Phillip Medghalchi
Dick, my Milwakee Drill went caput,and when i went to get parts for it they said it was discontinued, so they suggested to get the new one for $140. On the way home I stopped by Northern tool and got their angle drill and it comes with 5 yr warranty on it and told the manger what I do and he said it's fine just hold on to the receipt and anything happens just take it to the store and they give me a new one. So, I am planning on holding him to it. I haven't done much turning since end of Oct. so I report if it holds up or not. You amy want to check into it.
It's the one for $59.00. Here is the link:
Klutch Magnesium Close Quarter Drill — 3/8in.
