I took a perfectly good turning and cut it open, then bent it all out of shape. (Notice the zip-ties...they apply even pressure to help keep a round profile). To bend, I had to steam the "pith" out of it...you can still see the steam coming off the piece
Just curious, since you are bending, could you just start with a flat piece? I've never tried bending across the grain, but would imagine it would split down the grain pretty easily.
Have you ever tried using a backer strap which captures the edge to put the wood all in compression?
Hi Keith, I don't think a flat piece will bend far enough without breaking....plus, it wouldn't be turning! I've used backing plates to help form back bows for Windsor chairs, or various forms to bend against, but this really didn't need any help. An idea I'm working on, such as piercing a piece before bending will almost certainly need some kind of support to create a smooth curve. I appreciate you thoughts..
I agree. I don't think you could bend a flat piece that much unless it was veneer. Keith. I used hose clamps once to keep a green turned piece that was very thin from warping. It worked well. If I remember correctly it was out of round by .050" on either end. The bottom was about 6" across and the top was about 3". It was my heart lamp piece
