Carving for cat lovers and a sanding question
Darrin hill
Anyone ever use those sanding needles u can find at hobby stores? Wanting to do some fine tuning on this carving without using ruby carvers...
Darrin hill
Re: Carving for cat lovers and a sanding question
darrin hill
these things...
The carving is done combining a 1mm v gouge (By hand...) and a 1mm ball burr carver... The carver gives me a line to start and the gouge i can deepen the line into a v shaped valley.. but it looks rough and i want to fine tune the lines..
and i thought about doing gold leaf in the lines, but not sure if it would show...
don't want to burn the lines... and i don't know if just paint would make it look cool and old..
Im also going to add a bunch of hierglyphics from the book of the dead...
the backside of the vase is...
and
I also plan on rouging the lip a lot more... even thought about burying it in the yard for a while to age it ...
all the cracks are hand carved...
Dick Coers
Never done anything like that, nor used the sanding sticks. I just wanted to suggest triangular needle files, or rifflers. You can get the ones that curl towards the end so you can work them around a radius. Some suggestions for the lines would be a dark wax, rub n buff, or soft wire inlay. I would also suggest you throw some lines on a scrap to play with fill ideas. I've seen too many posts from people that experiment on the final piece, and then are asking how to fix it. LOVE the idea the work. Nicely done!
Ditto what Dick says. I have used the sanding sticks and sometimes they are just the right tool. They do wear out really quick. The rifflers and even diamond files with rounded shapes will do wonders although I find I have to keep a crepe stick or file cleaning brush handy to keep them cutting well.
Keith Newton
From what I'm getting of how you want it to look, I'm thinking you might want to try what Clay Foster does with tile grout, to get that look of having been buried for a spell.
What kind of wood is that?
darrin hill
Mesquite..
i've never seen any of clay's stuff closeup... and all i can see are full shots... no closeups...
can u describe the tile grout or find a pic?
Keith Tompkins
How 'bout some gold leaf and color?
darrin hill
color? Like variegated gold leaf?
Keith Tompkins
Now you're talkin' !! Gold, red, yellow....
Re: Carving for cat lovers and a sanding question *LINK*
Keith Newton
Have you ever tried your hand at incised carving with a knife? I used to do that quite a bit with my pocket knife sharpened similar to the blade in the link below. Rather than trying to use a bur, or V tool, I would cut one side, then the other to form a V groove. It is easier on even texture woods of medium to light density, but I found I had a lot more control doing that method.
Also, I think your design would be nice as a shallow bas-relief. Rather than a groove outlining each feather, it would look nice to just have a step down between the feather, with a slight hollow. I make my own small sanding disk using a small dime size diamond wheel on 1/8" shaft, with a fleece pad totally saturated with high strength spray contact cement. I then punch my abrasive paper out of larger disk that I keep on hand for my random orbit sanders. You can get a little air angle die-grinder cheap from HF for under $20. With this, I using about 180 - 220 grit, I could grind a feather faster than you could just do the groove, and end up with a smoother edge between them. Another benefit, is that the grinding doesn't care about quick grain change, so carving something like fiddleback maple is easy.
http://www.amazon.com/gp/aw/d/B000Q7AVL0/ref=mp_s_
Keith Tompkins
Agreed, THEN add color!
I see only one link made it in my post *LINK*
Keith Newton
I found these punches, which are reasonably priced, for making small sticky back disk out of larger 6" disks.
http://www.amazon.com/gp/aw/d/B000Q7AVL0/ref=mp_s_a_1_32?qid=1422348396&sr=8-32&pi=AC_SX110_SY165_QL70&dpPl=1&dpID=41vdv8e6qFL&ref=plSrch
