Remove Turpentine smell from Pine
Lloyd in Mississauga
A neighbour gave me a short section of log this summer to make them a couple of bowls from. The bark had long sense fallen off and they could not remember the type of tree as the wood had been at their cottage for a couple of years after being cut down and then they had it in their shed in the city for a couple of more years in hopes of cutting it up for a nice summer bon fire.
I did not really recognize the turpentine smell when I rough turned the bowls in July, but I did notice an odd odor that to me smelled like partially rotted wood, which this was.
I finished the bowls in early November with several coats of wipe on poly and salad bowl finish to try and cover up the odor. They they sat in the my basement for a month and still were "off gassing", so back out to the shop with them and it still came through today. So I sanded them back to as bare a wood surface I could get and now want to see if there is a way to reduce/remove the smell.
I had originally though it was soft maple or poplar, but after some research and the smell I am almost positive it was old pine. Bowls are probably not the best thing to make of this, but that is what they wanted.
Any ideas other than a bon fire?
Re: Remove Turpentine smell from Pine
Shellac
Dick Coers
It's known as the universal sealer. It's great at covering smells and stains. Even used to cover smoke damage from house fires.
Keith Newton
There are an assortment of chemicals which evaporate at different temperatures, which will set the pitch. I suppose you could use an oven, but I would suggest you do some research, because I wouldn't know how fast you could bring the heat up without causing problems.
But Dick's solution would probably be the path of least resistance.
Or you could just suggest that they display it in the bathroom, then everybody would just think they cleaned the bathroom with Pine Sol. Tee hee.
Lloyd in mississauga
Thanks, I was thinking the oven as well for a few hours in the evening.
I may try the shellac afterwards.
Thanks
make sure it's bone dry already
Dick Coers
or it will split in no time in an oven. Too much heat, too quickly! Well, unless your oven will hold at 90 degrees for a while.
Re: 1 done, one to go
The bowls were dry as they spent 4 months rough turned in my shed.
I oven roasted 1 for about 6 hours tonight at a low temperature in the oven and what a huge difference. The smell is 80% gone in that bowl, I think a good coat of shellac will now fix that one.
So tomorrow evening I will roast the other one to see if it works as well. The house reeked of turpentine all evening as the oven cooked away, but it seemed to have worked.
good news!
