risky business
risky business
Keith Tompkins
risky business
Keith Tompkins
Starting a new project....beginning life as a tube form. Notice that the piece is being held in the chuck after hollowing one end, then reversed to hollow the other end. There is no shoulder to set against the jaws, and minimum pressure applied, since the wall thickness is 1/8". All hollowing is with the Andre Martel hook tool, which applies the least amount of pressure to the turning since it cuts rather than scrapes, and the surface is clean, requiring little sanding. Home-built steadyrest to keep things in place. Even though there will be hours of carving, even us artsy turners need to know how to turn!
Re: risky business
Re: risky business
Dick Coers
Quite the fine example of craftsmanship of risk!
Re: risky business
Re: risky business
Dale Gillaspy
We need a "like" button.
Re: risky business
I'll second that!
Re: risky business
Re: risky business
Phillip Medghalchi
Keith, I like this set up. Can you post some pic. From the side so we can see the whole process, please. I am trying to figure out that how you are holding that pics on the chuck w/o any bottom to it. Appreciate it.
Re: risky business
Idea
Doug Wolf
Keith, Just an idea. To support the bottom, could you have just turned a plug to fit inside and then tighten the jaws around the tube with the plug inside for support. Or if you're expanding the jaws against the tube, turned a ring out of plywood to fit the outside diameter of the tube and expand the jaws against the tube and ring.
P.S. I love the work you've posted so far and I realize you don't need any help, you're doing just fine, keep it up. :)
Re: risky business
Keith Tompkins
Re: Idea
Keith Tompkins
Here is my usual method...turn a jam chuck/plug with a square shoulder, then glue the turning in place applying glue to just the face. Finish turning, then part off, having allowed a bit extra length to account for the width of the parting tool. This time, I just chucked the piece directly,feeling lucky :D
Re: risky business
Keith Tompkins
Re: risky business
Keith Tompkins
Here is a head-on image, tape prevents marring of the piece. Just finished sanding the exterior. I could have made a plug in each end and sanded between centers as well.
